C63 AMG (W204) 2008 - 2015
my c63 is too low and scrapes in garage , what can i do ?
Old Mar 1, 2009 | 06:09 AM
Dean Cole's Avatar
c63 amg
Exclamation my c63 is too low and scrapes in garage , what can i do ?
as i drive ever so slowly down into my garage, the bracket and tube (part of muffler) section thing underneath scrapes on the ground as i drive in , what can i do ? should i get the car raised 1cm ? thats all i need for total clearance .. any ideas would be great hear thanks
Old Mar 1, 2009 | 06:13 AM
xiaobingan's Avatar
C63
u may try some easier way, put some stuff (like wood board) on the "low" section of the ground, hope that helps
Old Mar 1, 2009 | 06:20 AM
Edi-no-son's Avatar
Mitsubishi evo9
i did it the way xiaobingan suggested.
My dad's c63 was scraping on the driveway too, and now we've plated 2 fat pieces of metal to raise the driveway and now its fine.
looks a bit ugly, but its better than a scratched c63....
Old Mar 1, 2009 | 06:23 AM
Dean Cole's Avatar
c63 amg
thanks Ed
any chance you can post a pic of your set up ?
Old Mar 1, 2009 | 06:42 AM
Edi-no-son's Avatar
Mitsubishi evo9
Heres my driveway...
From my understanding, your scraping should be the same as what my dad's c63 is, scratching on the bottom in the middle of the exhaust right??
If so, this will clear it.
Previously, it scraped every time going in and out, but with this setup, it clears it by a whole 1-2cm.
Hope that helped
Old Mar 1, 2009 | 08:05 AM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
You might want to check your tire pressure and add some air.
Old Mar 1, 2009 | 08:34 AM
Edi-no-son's Avatar
Mitsubishi evo9
I don't think increasing your tire pressure will increase the height by 1cm or more unless its really low or flat!!
Talking about tire pressure, what is it meant to be at approximately anyway??
Old Mar 1, 2009 | 10:13 AM
SebringSilver's Avatar
R8
Move to a different house.
Old Mar 1, 2009 | 11:31 AM
ygfamily21's Avatar
Porsche Cayman S
Old Mar 1, 2009 | 11:50 AM
tyanger's Avatar
09 C63 steel grey
are you driving up a slope or down (like in the pictures) as you pull into your garage?
Old Mar 1, 2009 | 12:00 PM
Sincity's Avatar
Enter and exit at an angle.
Old Mar 1, 2009 | 01:51 PM
mrtesting's Avatar
09' C63 AMG (Gisele)
Hahahahahahahahahaha! True say..
Old Mar 1, 2009 | 02:00 PM
tyanger's Avatar
09 C63 steel grey
This should work. used to drive a 93 300Z that was pretty low and never had problems with monster speed bumps and curbs by approaching at angles so one wheel contacts/leaves the elevated surface at a time. Applies to front/back and forward/reverse.
Old Mar 1, 2009 | 03:15 PM
norb's Avatar
2009 C63 AMG
Go in backwards.
Old Mar 1, 2009 | 03:21 PM
AMGC60-3's Avatar
One centimeter is very minimal, you would be surprised if your tires were under serviced and brought your pressure back to limitations what it will bring.
Old Mar 1, 2009 | 03:28 PM
nychokeyplaya35's Avatar
08' C350, Toyota Tundra
i have had the same problem with my m3, just go in almost sideways at a very big angle and you should be fine.....
Old Mar 1, 2009 | 03:42 PM
matt55's Avatar
09 c63 10 c300 Nissan truck
GRIOTS Garage has a heavy rubber strip for this exact application. IT spans the entire width of the curb Check it out it may be what you need.
Old Mar 1, 2009 | 03:54 PM
TA-9FF's Avatar
One with 4 wheels
Best solution here yet.
That or you keep those 2 ugly construction metal plates at the foot of your driveway forever.
Old Mar 1, 2009 | 05:38 PM
dlbello's Avatar
2009 C63 AMG Black on Black PP Package CF fully loaded
Get a contractor and just Fix the area with cement...
Old Mar 1, 2009 | 05:46 PM
Jae Duk's Avatar
'09 C63
Raise the car higher with hydrolics or something
Old Mar 1, 2009 | 08:08 PM
Edi-no-son's Avatar
Mitsubishi evo9
the angle method works if the driveway is wide enough.
If u look at my 1st photo, its not quite wide enough so can't do that
Tried that and failed... badly ><
Old Mar 2, 2009 | 08:05 AM
Dean Cole's Avatar
c63 amg
thanks for your help, cause i only took delivery the other day , tire pressure was 30 , should be 40 or a bit more... so i changed that and i took some of your advise above and entered and exited at an angle and it worked ! thanks again
Old Mar 2, 2009 | 08:16 AM
mzporto's Avatar
2009 C63 AMG / 2007 BMW 130i M Sport
Had an M3 and had the same issue. Works fine going with an angle. Just mind that the sides of the front bumper are also low, so don't go too fast or they will scratch.
Old Mar 2, 2009 | 08:27 AM
tangofoxtrot's Avatar
2009 C63 AMG Black/Black
I had the same problem with my M3. When I entered my driveway from the strret I kept bottoming out my car. I called my township to complain and they came and patched the asphalt (raised it up) and my problem was solved all free of cost. I would try calling your local Public Works department.
Old Mar 2, 2009 | 10:53 AM
SE7ENC55's Avatar
011 gtr
wow are these cars that low??
i have a b7 s4 and it never scratches.
is the c63 much lower?
