C63 AMG (W204) 2008 - 2015
Command's Bluetooth Interface
Old Mar 20, 2009 | 04:03 AM
Imprezive's Avatar
2015 GLA45 AMG, 2012 C63 AMG Coupe
Has there been a fix for the Command Bluetooth interface as yet?
I have been trying to find a fix to connect my Samsung Omnia to the handsfree kit for some time now, but no luck
Do you guys have problems connecting windows mobile6 phones to the Command system, eg: Blackberry, Samsung Omnia, etc...
I remember seeing a bluetooth adapter on the MB website, but dont see it there anymore.
Any advice would be appreciated.
Old Mar 20, 2009 | 04:31 AM
Jae Duk's Avatar
'09 C63
My blackberry pearl connects....
Old Mar 20, 2009 | 07:12 AM
alvchua's Avatar
Porsche 997.1 TT; BMW X5 35SD; BMW 2002tii; BMW 3.0 CS; BMW M635CSi; BMW 2002 Turbo
I use a Sony Xperia X1a which runs Windows Mobile 6.1- seems to connect with no problems i.e. able to dial and make phone calls. Cannot get the address book connected this way via bluetooth but have exported from my outlook address book to a SD card and loaded it via a PCMCIA SD card adaptor to the car's hard drive.
Was previously using the Iphone 3g - also able to connect via bluetooth but same problem with Address book syncing via bluetooth.
Old Mar 20, 2009 | 11:13 AM
dps01's Avatar
2009 C63 AMG
I can't seem to get my BlackBerry 8830 to connect. It worked fine in my 335Ci though...
Old Mar 20, 2009 | 11:17 AM
ARC101's Avatar
2008 C63
I do not have the upgraded media but working if I can still load the contacts via PCMCIA adaptor. Do I have that option without P2 package...?
Old Mar 20, 2009 | 11:25 AM
(ZO)'s Avatar
08 AMG C63
It took me some time to connect my 3G iphone to the car via BT. Try start the engine first and then try connecting it.
I have try at least 25+ times connecting it to the car, with no success, but when I give up and decided to start the car and drive off, I try it one more time with the engine on, in 15 seconds it found the iphone and ask for pairing confirmation.
Worth a try, but then again may be just luck.
Old Mar 20, 2009 | 12:29 PM
catesbym's Avatar
C63 09' LSD traded for 2010 GT-R
my Palm 755P connects without too much difficulty, just have to get the code punched in correctly. It usually takes a few trys, but I suspect it is the phones' issue not the cars.
Make sure your Bluetooth is set to "discoverable or visible".
I have not done the contact load since i have 4300+ contacts (business) I would have to convert to load. I don't think I can inport the PST file directly from Outlook, that would be easy.
Old Mar 20, 2009 | 03:00 PM
SebringSilver's Avatar
R8
The car's address book only allows 1,000 names to be stored, unfortunately. I know...because I've tried putting about 2,000 in there.
Old Mar 20, 2009 | 04:14 PM
dps01's Avatar
2009 C63 AMG
It's weird with my car since both devices see each other, but when I enter a passcode into both the connection fails. Any ideas folks?
Old Mar 20, 2009 | 07:50 PM
Ape's Avatar
Ape
2004 TL; 2004 S2000; 2009 C63; 2009 ML350
I think the passcode is "MBUSA" spelling that via the phone keys. i don't have a phone in front of me so I don't know the numbers that correspond to those letters.
Old Mar 20, 2009 | 08:35 PM
R8
hmmm... That's odd. When I paired myBlackBerry and my iPhone I was able to enter whichever passcode I wanted to.
Old Mar 20, 2009 | 09:48 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Yep. I chose a 4-digit code on the car then my phone prompted me for that code. Entered and linked up.
Old Mar 21, 2009 | 12:31 AM
DaGS1800's Avatar
09' C63 AMG
I had this problem with my blackberry at first too, You are just doing it wrong. It wouldnt find the phone automatically when I searched for a device. The password doesnt matter you have to set it up externally on the NAV (this feature is located under options) and the phohne must be set to send/recieve to bluetooth devices (with some phones you much manually activate this feature).
Old Mar 21, 2009 | 11:14 PM
Mrsl500's Avatar
SL
Hello guys,
The numbers they correspond too is 62872.
Heres a helpfull link that helped me pair up my new c class bluetooth.
This site also has links to other Mercedes Bluetooth pairing procedures.
http://mercedes-benzbluetooth.blogsp...h-pairing.html
Old Mar 23, 2009 | 01:57 AM
dps01's Avatar
2009 C63 AMG
Thank you! That worked like a charm. It's weird that some can program their own code (like my BMW) while some must use the 62872 code. Anyway, it's working great now!
Old Mar 23, 2009 | 03:20 PM
mzporto's Avatar
2009 C63 AMG / 2007 BMW 130i M Sport
yeah... i could choose the passcode I wanted to. Only problem is that I had to type it really fast (or the MB bluetooth would time out). I paired both iPhone and Treo.
Old Mar 23, 2009 | 08:33 PM
aqsc815616's Avatar
09 C63, 12 E350 4M
my bb storm connect fine
