Did u know we got
Brembo makes A LOT of OEM brakes. There is a significant difference from Brembo aftermarket and OEM however. My Toyota Tacoma also has Brembo brakes from the factory. If you look on the inside of the calipers, you can usually see the Brembo logo even on Toyota's and such.
They are Brembo, but nothing special or nothing to right home about. They certainly aren't these:
Then again, the chances of ever needing racing monoblocks on a C63 are slim to none. The stockers even non-PP cars are sufficient for most of us.
Here's Brembo GT brakes for an SL. $4300.00 on Ebay for just the front and they are only 6 piston replacements.
http://cgi.ebay.com/ebaymotors/405MM...ht_2327wt_1662
Full blown 8 piston monoblock racing brakes are probably between $8.5K-$9K for just the fronts. Add another $5K for rear brakes.
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
In case anyone's interested, here's the outsourced manufacturer list for parts on your car....
AGC Automotive Europe Rear door, rear door fix, Quarter light and backlight
Alfmeier Prazision Valves for fuel tank ventilation; brake vacuum check valves; seating comfort components
Autoliv Inflatable curtain side airbag; side airbag thorax for front and rear; seat-belt pre-tensioner
BASF E-coat and basecoat for Sindelfingen; primer and basecoat for Bremen
Behr Standard two-zone HVAC module; optional three-zone system
Behr Hella Thermocontrol Solar sensor, PTC controller and linear blower controller
Benecke-Kaliko Tepeo2 film for instrument panel; Tepeo expanded vinyl for door trim; PVC expanded leatherette for seats.
BERU Instant start system for diesels; spark plugs for gasolines
Brose Door closure systems and seat adjusters
Bosch Common rail injection diesel system; gasoline ECU; starter; alternator; spark plugs; body computer; wiper system; engine cooling blower module; park assistance system; auxiliary electric water pump; various sensors
Brembo For AMG version: front monobloc brake caliper (6 pistons); front composite brake disc (dia 360x36 mm); rear monobloc brake caliper (4 pistons); rear brake disc (diam. 330x28 mm)
Brose Door modules
Continental ESC system, brake booster, brake hoses and calipers, Continuous Damping Control, Door control unit, telematic unit for E-Call, hill start assist, trailer stability control
Contitech Ribbed V-belts, fuel management system; diaphragms; steering boots
Delphi Wiring system, including three large wiring harnesses for engine compartment, centre console and interior; antennae array, occupant detection system, alarm, switches satellite and digital radio; common rail diesel system in the 220 CDI
Dow Automotive Structural bonding; interior trim
Draexlmaier Interior centre console, gear shift, electrical components: electric box, power distribution box, gear indicator
Dura Roof mouldings (for option version glass roof); door release cables; trunk release cables; hood release cables
Eberspaecher Exhaust systems for all gasoline versions.
ElringKlinger C 200/220 CD: cylinder-head gasket (the new gasket generation with honey comb stopper), specialty gaskets; C320 CDI: cylinder-head gasket, specialty gasket, shielding systems; C230, 280, 350: One specialty gasket
Freudenberg Seals
FS Fehrer Automotive Upholstery for car seating; rear centre armrest; side bolsters for rear seat back
Grammer Crash active front and rear headrests
Harman Kardon Dolby surround sound system with 12 loudspeakers and a 450-watt digital amplifier.
Harman/Becker Infotainment system including voice control navigation
Hella License plate lamp, interior lights, side marker lamp, overhead console, central modules, water level sensor, intelligent battery sensor, actuators, headlamp cleaning unit
HellermannTyton Waterproof parts for doors; customised fixing solutions for engine harness, cockpit harness, seat harness, brake lines, oil lines, fuel lines
Hirschmann Automotive Harness for brake lining wear indication; harness for ABS; harness for angle-of-rotation sensors; switches for sensor applications; cable harness for parking assistance; connectors for driving authorisation systems; micro-gas generators; contact housings
Hirschvogel Aluminium Rear-axle knuckles
Inalfa Panoramic glass sunroof
Johann Borgers Complete luggage compartment trim; parcel shelf
Johnson Controls Headliner, sunvisors,grab handles, rear seat structure, instrument panel, seating components, integrated garage door opener, park distance warning
Kautex Textron Tier two supplier of air ducts to Johnson
Lydall Gerhardi Underbody heat shields
Magneti Marelli Headlamps: halogen, bi-xenon and bi-xenon adaptive front light systems
Mahle Oil filter modules and oil filter elements, activated carbon canisters, oil mist separators, air filters, camshafts, valves, valve guides and valve seat inserts, pistons, piston pins and cylinder liners
Mann+Hummel Oil filters and air cleaners for V6 gasoline and diesel engines
Otto Fuchs 16’’ forged aluminum wheels; suspension parts and wishbones
Pilkington Automotive All glass for saloon; windscreens and front doors for the estate.
Piolax Glovebox damper unit
PPG Clearcoat and black, white and silver basecoats to Bremen
Rehau Bumpers with integrated pedestrian protection
Rieter Aerodynamic underbody shields and heatshields
Röchling Automotive Washer bottles.
Schefenacker Tail lights with air outlet; LED rear indicators; prismatic interior mirrors; high-mounted brake lights
Takata-Petri Steering wheel airbag, driver airbag, passenger airbag, knee airbags
Teleflex PTFE brake hose
ThyssenKrupp Technologies Roof frames; pedal boxes; steering gears; differential bevel gears; sun gears; monoblock reverse gears; crankshafts (forged).
TI Automotive Plastic fuel tank; filler pipe; pump/module for all ECE variants (the M271 4-cylinder engine); brake & fuel tubes to South Africa plant
TMD Friction Brake friction materials for front axle
TRW Engineered Fasteners & Components Fasteners; pressure relief valve; jack support; pipe clips
Vibracoustic Engine mount for diesel engines; hydraulic bushing for front suspension; cross link bushing; rear differential mounts including support; tie bar bushing; spring link bushing; push ABR bushing
Voestalpine Polynorm Plastics Underbody engine noise shields
Voestalpine Steel Electrolytic galvanized steel for: frontdoors’ inner and outer; trunk lid outer; wheelarches; various structural parts
Webasto Sunroof
Winkelmann Powertrain Torsional vibration dampers; starter gear rings for V8 gasoline; metal and plastic pulleys
ZF Chassis components; dual-mass-flywheel (for station wagon starting 2008); monotubes at rear; struts
ZF Lenksysteme Steering pump; hydraulic power steering gear for the 4matic version
Brose Door modules
Freudenberg Seals
Webasto Sunroof
Paid around $6k for my full Brembo gran turismos. 6 piston front, 4 rears, drilled rotors. Including custom powdercoat and install.
i actually want to know exactly what are the differences between the calipers on our cars and the brembo monobloc you can get aftermarket as they look completely the same. the discs are different i know but the calipers look exactly the same to me. please enlighten me!
According to Azn's outsourcing list, they should be brembo monoblocks. They certainly look about the same as his white Granturismos, asides the rotors of course.
Makes you wonder, you should be able to buy brembo 2pc rotors for both front and back instead of OEM PP rotors and evosport rears and who knows, they might even be cheaper.
09' C63 AMG
I don’t understand, for all that money you put into a regular C-class (because I am sure if you buy a 6k braking system you will do much more modding) wouldn’t you rather have a stock C63?? It seems pointless to put brakes like that on a C350 when the car doesn’t even perform fast enough to even need that braking system... Besides that point it just seems ironic...
2013 ML63 AMG PP
oops...
Oh yes, silly me..., I should have said: 'All I know is the standard, specially developed, AMG high-performance 4-wheel disc brakes that are internally ventilated and perforated, on the C63, are awesome!!!'
