ECU Removal!
2009 C63 AMG, 2013 ML350 BlueTec, 2012 VW GLI
ECU Removal!
Hi, this has probably been asked before but how do you remove the ecu once you have the cover off? I don't want to force the connections on top too hard, do you slide them left or right or just pull on them?
Sending it to Kleemann as soon as I remove it.
2017 AMG C63S Coupe , Range Rover Sport
Here you go.......Cheers John
This will give some idea from a different model but you just pull the ECU straight up once you have disconnected the two plugs .
https://mbworld.org/forums/c-class-w...oval-pics.html
