DIY - ECU removal with pics
Old Mar 25, 2009 | 01:00 AM
Bokx_350's Avatar
C350
Removing/installing the ECU is a 10 minutes process… IF you know how to do it; otherwise it can be a headache and you could end up damaging something.
I decided to write this DIY because the instructions I received from my tunner where useless. So if anyone is planning to get an ECU tune, or want to remove/install the ECU for whatever reason, here it is.
Things to know before you begin:
1. You don’t need any tools for this
2. The car needs to be cold since the ECU sits on top of the engine and it gets really hot; so don’t expect to drive home and start working right away.
3. Once you remove the ECU you will not be able to turn the car on, so do it somewhere where you can leave your car without problems. For instant, not behind your wife’s car.
4. It is advised to disconnect the battery for this procedure, although I didn’t do it and my car didn’t blow.
First you need to remove the plastic cover in front of the air box. It will pop off with very little pressure. Then you need to disconnenct the 2 intake hoses plus a third smaller hose from the air box. These are also snapped in and are flexible enough to come off without hassle.
With all the hoses off, you can now pop up the air box. I suggest you store both the air box and the plastic cover in the trunk.
The ECU is hold in place by four rubber pegs, you can now lift it up to get enough room to disconnect it.
There are two harnesses you will need to disconnect on the back of the ECU. Notice that the plastic plug where the harnesses are connected is actually part of the ECU. DO NOT pull them in any way. To disconnect the harnesses you simply pull on the plastic lock on the side and they will come off.
You are done. To reinstall is simply the reverse, be sure to snap in all four of the airbox corners and that all the air hoses are all the way in.
Attached Thumbnails DIY - ECU removal with pics-hoses.jpg   DIY - ECU removal with pics-lock.jpg   DIY - ECU removal with pics-wo-airbox.jpg
Old Mar 25, 2009 | 01:04 AM
BerBer63's Avatar
2009 C63
God bless you.
Old Mar 25, 2009 | 01:59 AM
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
That's some good info.
Old Mar 25, 2009 | 02:09 AM
Rampage1929's Avatar
2008 C350 Sport
Thumbs up
Old Mar 25, 2009 | 02:52 AM
micropower99's Avatar
2008 Mercedes C300 4Matic
Finally! Thanks for the post man!
Old Mar 25, 2009 | 04:37 AM
cdye12's Avatar
09 C350
+1
Old Mar 25, 2009 | 07:19 AM
white_glass_top's Avatar
2008 C300 SPORT (white)
Thumbs up
Great post!!
Next question(s), has anyone ordered a aftermarket ECU Upgrade and from where?? And was it worth it, if so?
Old Mar 25, 2009 | 10:57 AM
kit0515's Avatar
C350 4Matic
Originally Posted by white_glass_top
Great post!!
yeah, i really want to know too, i am thinking of going to find a totalled c350 and see if i can use teh ECU so i can have it tuned
Old Mar 25, 2009 | 12:38 PM
Bokx_350's Avatar
C350
Thanks guys. I'm just glad I could contribute to the forum
Old Mar 25, 2009 | 01:03 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Wow, I feel really dumb now because that's NOT where I have been envisioning it all this time, I thought it was under the dash near the pedals....
Awesome DIY write up! Two thumbs up!
Old Mar 25, 2009 | 01:06 PM
Krytech's Avatar
Great post!!
Yep, just check the OP's other post titled "MKB ECU upgrade comming up!!"
linky
Old Mar 25, 2009 | 02:03 PM
BerBer63's Avatar
2009 C63
Stick This!
Old Jul 18, 2009 | 04:28 AM
CreditGuy's Avatar
2008 C-350 Sport
Question, where can you get an upgraded ecu? benefits on a c-35- auto? negatives?
Old Aug 24, 2009 | 01:24 PM
Peabody's Avatar
I live in Germany, and I asked the Carlson tuners who handle all the MB, and they said that the series sedans will not benefit from an ECU tune, and they only do ECU tuning for the AMG. I can't imagine that it would be worthless, but that's what the MB experts here say.
Old Aug 24, 2009 | 01:32 PM
M-bENZ's Avatar
Corrolla
it that really?
Andy
Old Aug 24, 2009 | 02:13 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I call on that. I believe ANY stock car will benefit from a properly tuned ECU. Maybe they think owners of the smaller engine cars are not a large target group for performance upgrades and it would not be cost effective. Don't they realize WE are the ones that need the help?
Old Aug 24, 2009 | 03:06 PM
Peabody's Avatar
Yeah, I don't have a clue why but I think they quoted me around 1600 euro for an ecu tune until they realized it was only a C350, at which point they told me they wouldn't do it. I think it might be something between MB and Carlson, because they did not seem very eager to do any work on my series sedan.
EDIT: Also, if anyone knows how to remove the speed limiter from the ECU.. I am more interested in that than the actual tuning part. My old Peugeot had a higher top speed than my new Merc!
Old Aug 25, 2009 | 12:29 AM
burnteggroll's Avatar
w204 - 350 N other white cars
very nice write up and easy to understand...
Old Aug 26, 2009 | 12:45 PM
Peabody's Avatar
That was a thread hijack, starting a new thread.
Old Sep 29, 2009 | 08:29 PM
rooban_21's Avatar
w204
Why would one want to upgrade his/her ecu?
Old Sep 29, 2009 | 08:40 PM
imboom's Avatar
Power. In some cases with some cars with a few or more than a few engine modifications, a tune is very beneficial as you can take even more advantage in the engine parts you put in as well is to modify the useful power range of the car.
Old Mar 12, 2010 | 09:02 PM
charliele729's Avatar
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Would pulling off the harness of the ECU reset the ECU?
Old Sep 19, 2010 | 03:42 PM
mikelin7's Avatar
'86 190E, '93 CAMRY V6 XLE, '94 626-LXV6, '96 328is, '09 C350
why would mercedes put the ECU on the hottest spot in the engine bay
Old Sep 19, 2010 | 06:05 PM
Samieee's Avatar
C
They wanted to make the hottest ECU on the market
Old Dec 3, 2010 | 12:59 AM
mr inkredibul's Avatar
'17 GTR, '17 GLC43, '14 Panigale 899, '20 V4
Funny lol
All I can say is to remove the top portion of the airbox, you need to slide the silver retaining ring back first before you pull off the top.
