Changing HIGH BEAMS only!
2009 C63 AMG, 2013 ML350 BlueTec, 2012 VW GLI
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
Can't seem to remove the bulb for the hi-beams. Can't remove metal ring holding them in place and too scared to force it and snap it off. Already changed my Xenon bulbs, that was easy, but cant get the hi's out.
Any help is appreciated.
You already need to change your Xenon bulbs already? Or do you have a P1 and changed out the stock bulb? If so, what did you replace it with?
By the way, changing the Hi-Beams is definitely not the same procedure as the Xenon bulbs. Still can't release them from the clips.
