C63 AMG (W204) 2008 - 2015
Winter tires
Old 08-25-2009, 12:42 AM
-michael-'s Avatar
2009 MB C63 2007 MB ML63 2006 MB CLS 500 (wife)
Winter tires
Can anybody recommend a good winter tire?
And what is a good size for winter tires on C63?
TIA
Old 08-25-2009, 01:21 AM
Veho's Avatar
2014 CLS63 s-amg, 2012 Porsche Cayenne, ML350
How does the C63 handle the snow and do you all change tires for the winter? (I live in New York)...
Old 08-25-2009, 06:52 AM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
All tires have to be changed in order not to kill yourself. The Pirelli winters are good on this car.
Old 08-25-2009, 05:23 PM
MikeS54's Avatar
C63 AMG
i would still suggest Bridgestone LM 25 over the Pirelli wintersport series. LM25 is the ultimate winter it is what they used on the GTR's winter nurburgring snow run.
Old 08-25-2009, 08:15 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Winter 240 Sottozero Serie II
http://www.tirerack.com/tires/tires....ozero+Serie+II
Old 08-25-2009, 08:23 PM
amg07's Avatar
I second that. Used them last winter and they are great tires. Downsized the width per the recommendations in the C63 Owner's Manual (provides a bit extra bite)
Old 08-25-2009, 10:48 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
What sizes did people use? 225/40/18 in the front and 235/40/18 for the rear if you use the stock 18" rims? i'm considering getting some 19" rims so my stock rims can be used for snow tires. would the 235 fit on the rear though?
Old 08-26-2009, 07:05 AM
1st amg's Avatar
I used the exact same factory setup for tire sizes.
Old 08-26-2009, 09:25 AM
235.40.18's on all 4 corners (used my stock wheels)
Old 08-26-2009, 10:41 AM
Balz's Avatar
C63, LR3
I usually keep it in the garage...
Old 08-26-2009, 10:49 AM
MikeG_C63_AMG's Avatar
09 Eurocharged C63 AMG
+1
I either drive the GF's TSX or my brother's 04 S4 in the winter when it snows. The S4 with the V8 is a monster in the snow it goes through just about anything with a nice winter tire set-up. I got stuck once last year in the snow with the C63. I had to basically abandon the car in a church parking lot after almost wiping out a few times. Very VERY scary scenario. Do NOT drive this car with performance tires on in the snow.
Old 08-26-2009, 01:15 PM
Former Vendor of MBWorld
ALLDATAdiy INFO's Avatar
Mercedes
TIA
What kind of winter conditions are you driving in? Moscow or LA?
Old 08-26-2009, 03:05 PM
gsrjc's Avatar
I kept my C63 in the garage last winter but I might need to take it out a little this winter.
Old 08-26-2009, 03:36 PM
-michael-'s Avatar
Moscow.
There is not much snow (melts a lot) in the city in winter (that's where I usually drive) and most of the winter is wet (because of the melted snow).
Some people in Moscow use studded winter tires, but I'm not a fan of those. I had one set on CLS 500 and by the end of the winter 75% of the studs were gone.
Old 09-02-2009, 10:26 PM
dockt's Avatar
'09 C63 AMG
TIA
also looking for advice. thanks.
Old 09-09-2009, 04:44 PM
Veho's Avatar
Looks like im going with the blizzak and will get new rims as well.. Im thinking of getting the same size as the standard amg wheel (235/40front and 255/35 rear) so I can switch the rims for summer or winter tires as I like.
Old 09-09-2009, 09:13 PM
andrew89930's Avatar
2009 C63
park it and get something worth under ten grand to wreck : ) LOL
Old 09-11-2009, 10:51 PM
gsrjc's Avatar
so tirerack recommends 225/40/18 as the tire... is it okay to run this all-around?
Old 09-11-2009, 11:42 PM
mderka's Avatar
c63, r320 bluetec
Thats what I ran last year. Purchased a complete set from tire rack with alloys for about $1200. Car was rock solid in the northeast winter.
I think I have michelins, but Can't remember. Tires are out in the barn.
Old 09-12-2009, 12:49 AM
c63canada's Avatar
c63 amg
Smile
I also purchased mine at tire rack. 225/40 18 with 4 wheels. tire are dunlop 3D. works well in deep snow and we get a lot of it over here. Blizzack are very soft but great on ice. but you will probably wear them out in one season. Pirelli great for sport driving, not so great in deep snow. just look at the tread pattern.
Old 09-14-2009, 09:47 PM
gsrjc's Avatar
Would you recommend the Dunlop 3D over the Blizzak LM25?
Old 09-15-2009, 08:38 PM
c63canada's Avatar
c63 amg
The dunlop, I Think are less expensive,. They work great. If you don't care about the money go with the blizzack but be advised that it is a soft compound that sticks to ice but will wear out faster especially in the rear. If you want to drive like its summer during winter, go with the pirellis and you could also keep the same size as the summer tires.
The recommended size by MB in the cas cap cover for the winter is 225-40-18
Old 09-15-2009, 08:52 PM
dockt's Avatar
'09 C63 AMG
for people who bought 225 or 235's, did it look weird on the stock rear wheels (i think 9.5" width)?
Old 09-15-2009, 09:28 PM
CDNROCKIES's Avatar
'08 IS F; '09 ML 320 Bluetec; '10 X5 35d
I don't have a C63, but I will say that the Blizzak LM25V's are incredible winter tires. I see more snow and ice than probably 99% of the people here and had zero issues with mine last year. Wear isn't really an issue either as I switched to standard set up for the winter, so I can now rotate my wheels.
I also downsized to the 18's that are being discussed, and while they don't fill the wheel well like I'd like, they certainly get the job done when it counts.
Old 09-15-2009, 10:31 PM
soccerg201's Avatar
GL550
2 more to add to the list:
Hakkapeliitta
Vredestein
I had hakkapeliita rsi's on my car and they were amayzing. I am getting the vredestein wintrac extreme for this winter. They are supposed to be great in the snow but also keep great performance.
http://www.tirefactory.net/wintracxtreme.htm
Quick Reply: Winter tires
