how do you remove the charcoal filters
Lets be honest these are not Green engines. That Gas Guzzler tax that you all paid for it says so.
i had my car in today for rear tires (will update on the brand I chose--only 180 a pop and so far, great performance!).
anyhow, i asked for those filters to be removed. my dealer would not do it
said it would impact emissions and may throw a light. i'm thinking bs, but whatever. i'll just do it myself.
The charcoal filters came out easily. In another 15,000mi. or so, I will replace my oem paper filters with BMC drop-in air filters. btw -- Charcoal filters like the ones used as cabin air filters are used to remove odors, pollen, and such. But why have these charcoal air filters (along side the regular paper air filters) in the intake if the outside air is just getting sucked into the engine?
Perhaps you should stick to bringing your vehicle to perf. shop or dealer in the future to avoid further damage.
Are you saying you have a screw loose?
JK...
Did you miss a screw and try to force it off? How did this happen?
1) Remove the center section (with MB star) by lifting it up carefully.
2) Remove the T25 screws on each airbox.
3) Unscrew the hose clamp on each rubber tube.
4) Lift and pull airbox top out.
5) Turn over and remove charcoal filter (which is UNDER the oem stock paper air filter).
6) Reassemble.
Assembly tip: When screwing the tops back on, I would insert the screw and turn it (with your fingers) counter-clockwise till I feel it "click" and then turn it clockwise to start the screw. Then use your screwdriver. If you do it this way, you will not re-tap the plastic and possibly cause problems in screwing the box tops down in the future.
