C63 AMG (W204) 2008 - 2015
C63 Strut Tower Brace - By SMERC Engineering
Old 12-31-2009 | 02:19 AM
JM's Avatar
JM
W204
Sincity, I knew it was your car without even scrolling down...
i can see the rims haha
stunning car
Old 12-31-2009 | 12:34 PM
Sincity's Avatar
Originally Posted by 1Lop2K5C
Nice bar, how hard is it to remove the unit if you need to service the car? Are you considering makinng one for the W209/203?
The bar just unbolts form the mounts; less than 5 minutes. You will need to ask SMERC if they plan on producing other bars.
Thanks!
Old 12-31-2009 | 05:03 PM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Btw smerc was out of stock for W204 last time I spoke to them (they are trying to find a new manufacturer for the part). Please let us know when they are back in stock.
Old 12-31-2009 | 05:33 PM
Thericker's Avatar
V12-Biturbo
Very nice product!
Originally Posted by SMERC Engineering
SMERC Engineering's proud to announce our W204 C-Class Strut Tower Brace.
Applications:
C63, C300, C350 (2008+) *includes all 4matics
Features:
- CNC'd T-6061 Aluminum Brace (high strength, light weight)
- 3/16" A36 Plate Mounts
- Flat Black Anodization Protection on Brace
- Flat Black Powdercoated Mounts (with fine texture) for durability
- Easy Bolt-on Installation with easy removal for access to intake airbox
Smerc Engineering's Strut Tower Brace is designed to connect the front suspension towers together for better handling. During cornering, the Strut Brace will distribute the vertical suspension load between each tower, thus reducing strut tower flex & chassis flex.
Our product features the use of premium grade T-6061 Aluminum, which is known for its high strength, yet light weight properties. The aluminum first goes through a CNC machining process for precision engineering and consistent product output. Although Aluminum naturally resists corrosion better then various metals, to fully ensure corrosion resistance the strut tower brace is put through an anodization process. The anodization will also help protect the aluminum for wear.
The brace is designed for a quick and easy bolt-on installation. There is absolutely no drilling or cutting necessary. A quick 5 to 10min installation by using our detailed instructions. Our design allows for easy access to the intake airboxes.
Price: $329.99
Please feel free to PM us to order, or visit our website http://www.SmercEngineering.com
Best Regards,
Yuta @ SMERC Engineering
yuta@smercengineering.com
Any chance of making an application for us R230 SL owners I know @ least half a dozen owners that'd be interested
Quick Reply: C63 Strut Tower Brace - By SMERC Engineering
