C63 Snow Usage...Anyone??
1 Post
2011 GLK350, 2010 ML350, 2008 C63 AMG
if you are running the recommended winter tire size by MB 225/18 all around, the recomended tire pressure is from what i understand 43 psi all around. Check inside your gas cap. it says + 4 psi for warm tires or winter tires. So I guess that's 39 + 4 = 43 psi. That's what I'm running right now.
C63 AMG (Performance & Premium Package) Audi RS4
Echo mcc3436
I just put brand new Conti winter contact's on. i also am an experienced winter driver and we get BAD conditions. The C63 is an OK winter driver at best. I got stuck outside my driveway last night. I had an Audi RS4 prior to the C63 and it was MUCH better in the ice and snow. The C63 is still a blast and I am enjoying every minute of it; I am however discovering the limitations of huge torque in a RWD car in slippery conditions.
I don't think you are correct with the tire pressures. I believe that +4 means that if you measure the tire pressures when they are warm then they will be 43 psi but if you measure them at the cool temperatures, you should set them at 39psi. I don't recall seeing the +4 psi for winter tires but I guess I should look again. Nonetheless though, the +4 takes into account the air warming up in the tires when they get warm and it doesn't mean you should set them at 43 psi if they are cool. I didn't know if there were specific measurements based upon the different tire sizes. So i guess there isn't so I'll run 39psi when the tires are cool.
"warm tires up to + 4 psi"
and just underneat "225/40 R 18 92V extra load M&S + 4 psi"
It does make some sense because since the pressure exerted by the weight of the car on a slimmer tire is going to be greater per square inch you would have to put more air pressure inside the tires to compensate.
just my thoughts
2014 Lotus Evora S
I run on 225/40 all around. I was kind of happy to get snow this week in Toronto to see how the car drives in the snow. I expected the car to be just dangerous to drive in the snow even with good winter tires. I was pleasantly surprised that I was not spinning (transmission set on C) when starting from traffic lights and the car was much more stable than I expected. So good news overall.
However, given the high power for the weight, it's probably not the best car ever for winter driving.
If you want a car for winter buy an audi 4 wheel drive or just about anything 4 wheel drive. Don't forget that the winter last only about 4 months, (at least in montreal). And of those 4 months you're driving 80 to 90% of the time on dry roads. Just drive safe when the wheather is bad and you won't have any problems.
Then enjoy the devastating torque and handling during all the rest of the year.
1 Post
Maybe i'm wrong but if you look inside the gas gas here's what it says. I have a canadian model so I don't know if it is the same sticker as in the USA.
just my thoughts
just my thoughts
#32
C63 AMG / B8 A4
Absolutely. The car, when equipped with proper snow tires, behaves impeccably in the winter. Ice is a bit trickier than snow, however, so you still have to be careful as I'm sure you know.
(Sidenote: I see you a fair bit over on Audizine. Nice to see you over here as well! )
Great to hear that. I actually just purchased a set of 18" wheels and Blizzak tires for the C63. I have the 09 A4, but incase I get stuck in bad weather, I'll feel confident the 63 can get home
Yeah, I still pop onto Audizine. I knew that your screen name was familiar, I just didnt put 2 and 2 together. Good to see you on here bud!
#33
pics of my c63 with winter wheels
Here it is 225/40 dunlop 3d on 18s elbrus wheels
Also try to dry your brakes by braking hard a few times before parking your car. Especially if you are not going to drive it for a few days. For example if you only use it once in a while during winter time.
That way you will avoid rust formation on the rotors caused by salty road slime drying on the rotors.
#35
bought them at tire rack last year.
wheels were 125$ each and 169$ for each tire. Way less than what the dealer was recommending.
Love them.
ciao
#36
I know others have said that the C63 makes it fine through the snow, but as an excellent (IMHO) and VERY experienced Winter driver, I would have to say that the C63 is by far the worst Winter driver I have ever owned, and that includes tons of HP cars.
Last year, I could not even get out of my slightly hilly driveway, and that was with a great set of snows on the C63. Therefore, it spent most of the time parked since my ML430 with a 107K miles on it is a veritable Snow Beast for skiiing.
Good luck and safe motoring!
Of course it won't compare to a ML430. AWD, with way more ride height and softer suspension, there's no comparison. Any AWD car with all seasons is WAY better than any 2WD car with winters getting going.
#37
The 225 looks goofy - but it's correct. Remember, in the winter you want the smallest wheel possible. The wider it is the more it slides around.
The Tirerack sizes are from my car. I went in a year ago and they put the car up on a CAD bench and measured all the sizing info using a 3d digitizing pen. It was very cool - the result is the size we have and it's identical in fitment to the E55 which was in the database from years of old.
#38
1 Post
#39
I have the same package. I had to shift the balancing weights a bit because they weren't straight and it was rubbing. Everything is cool now, but I only have about a mm of clearance its really toight. Rims look pretty good for being so cheap.
#40
1 Post
i think things are good.
#41
C63, Scuderia, 599, 16M, AEV Hemi Jeep, '57 Porsche Speedster, '55 300SL, SLS on order
I have dedicated Vredenstein snows (wintracs) on dedicated AMG wheels - bottom line is the car is surely performance biased and a bear in the snow regardless. Note that I have driven cars in the snow for 25 years; however, the C63 is a car I park when the snow accumulates, even with my experience and the VRs.
#42
2008 BMW 335 / 2008 Chev Silverado / 2010 Merc C63 AMG / 1987 Lamborghini Countach
I put the same set up on my 63...Black MSW's, look good, fit right, I had TireRack put the Tire sensors in also, but have been having problems with them constantly having to be reset? I live in the UP of Michigan, lots of snow & ice...car is ok in snow, very dangerous on ice-rutted roads...rear wants fly around...not good! My 2008 Chevy Silverado is a dream machine in these conditions compared to the C63...ya should leave it in the garage when it's iffy.
#43
1 Post
#44
4 Dunlop SP Wintersport 3d's 235/40/18 on Rial wheels. A Tirerack package. We've had several snowfalls in the last month or so.
NO ISSUES whatsoever. Outstanding snow performance. Now getting hit by other *******s driving around thinking about everything but DRIVING is a different story. No issues with clearances with the Rial wheels and the TPMS have been spot on.
#45
We got a light dusting last night
I'm riding on a set of 18" SL55 AMG multispoke/turbine wheels with brand new Michelin Pilot Alpine PA2's (winter tires)
235/40/18 fronts 255/40/18 rears
#47
2009 C63 AMG, 2013 ML350 BlueTec, 2012 VW GLI
Used OEM Rims with Dunlop 3D SP 235/40/18 tires on all 4's.
Pretty good once you get moving. Keep Traction Control OFF and they're even better.
TC doesn't allow the tires to bite enough. I was actually having more trouble on SPORT and Full TC than with TC off. Wierd huh?
