C63 Snow Usage...Anyone??
2010 Irridium Silver MB C63 AMG Sedan
Want to get a disscussion going on anyone on the east/midwest using their C63's in the snow. I just moved here from San Diego (born and raised) for business. But rear wheel drive? Salt? Moisture? Salt rocks hitting the paint? Slipping? How much torture can these babies take? What are your takes on not taking them out until it clears up in April and care while they sit in the garage...And to all you guys that are going to rub it in that your in Cali...Chillout...I already know how good you have it.
The C of 63's
I have been driving the c for two weeks in some of the worse road conditions i have seen in Calgary and coming from a S4 I'm really surprised at how well the 63 performs in slippery conditions. Other then pulling away from a dead stop, it is very Audi like once it is moving. I did purchase sotto zero's which help a lot but ya she is making out ok as a winter driver!
Sebringsilver, Benyl, SICK PICS!!!!!!!!!...Rugged and unstopable!!! Post some more angles!! How is your performance?! What tire types?! Any slippage issues?!
R8
Absolutely. The car, when equipped with proper snow tires, behaves impeccably in the winter. Ice is a bit trickier than snow, however, so you still have to be careful as I'm sure you know.
(Sidenote: I see you a fair bit over on Audizine. Nice to see you over here as well! )
R8
If you're ordering snow tires for your OEM wheels, I believe most of us are using 235/40ZR-18 both front and rear. I'm sure others will chime in with their thoughts as well.
Good luck.
C63 AMG
Unfortunately, I didn't take any more photos that actually show the car on that particular occasion. It does do pretty well in the snow, so if the point of your thread is to ascertain how practical it is in the winter, I don't think you should be too worried. I ran Hankook W300 IceBears last year when we had that huge snowfall, and didn't really have any problems. I did need a push on one occasion when there was some hard-packed ice underneath the snow, but other than that, it was all good.
Good luck.
Good luck.
Get yourself some same size wheels (same as E class) and proper snow tires - as narrow as possible - and enjoy. I'm in Naperville and the car is fantastic in the white stuff. Highly predictable, easy to drive and in fact I was out running 4x4's on "all season" rubber yesterday and laughing to the exhaust noise.
Driving it on Blizzaks, and so far so good. Last winter I garaged it and drove my S4, but decided to sell that car and consolidate to 2 after what I'd heard/read about people doing fine w/ snow tires on the AMG.
R8
I live in Calgary as well, and got my C63 as a winter car. Nice thing about Matte Black, snow doesn't stick to it at all!
We got a rediculous amount of snow, and have been driving the C63 fine everyday. Like SebringSilver, I'm using the Hankooks IceBears for winters. They're OK in the snow and ice, it's the cold dry performance that's awesome. They have really good dry grip for a winter tire.
I drive pretty much with ESP-Sport mode, all the time, and ESP-Off at nights. ESP sport gives enough wheelspin to get going a lot easier from a stop (ESP-On is TOO intrusive), and ESP-Off when nobody's around so I can drive like an @sshole.
1 Post
2011 GLK350, 2010 ML350, 2008 C63 AMG
Is it okay to use 225/40/18? That is what they recommended at Tirerack with 18x8 rims with a +48 offset. I figured if Tirerack recommended it then it should work. I also believe that with the 225, I'd probably get a little more dig through the snow.
Does anyone know what backspacing means for a rim? I thought the only worry for aftermarket rims was to get a correct offset.
ok in snow storm with 225/40
we just had a snow storm in montreal today. drove the car to and from work. no issues at all. I got a set of 4 wheels and 4 225/40 dunlop 3d and they work fine.
i'm sure that the 2nd battery that is in the trunk helps with weight distribution and improves the traction of the car.
bought the wheels and tires from tire rack. wheels were 121$ each. Dunlop were not too expensive either.
1 Post
04 w211 E55
I dunno but 225 on a C63 would look sort of funky no? I have 275 rear and i cant imagine 225 on this car. I understand it is for the winter but I want the car looking its best all 4 seasons. Then again I have a G35X for the snow so some people need to use whatevr they have.
2015 BMW M3 White/Black
Last year, I could not even get out of my slightly hilly driveway, and that was with a great set of snows on the C63. Therefore, it spent most of the time parked since my ML430 with a 107K miles on it is a veritable Snow Beast for skiiing.
Good luck and safe motoring!
if you are running the recommended winter tire size by MB 225/18 all around, the recomended tire pressure is from what i understand 43 psi all around. Check inside your gas cap. it says + 4 psi for warm tires or winter tires. So I guess that's 39 + 4 = 43 psi. That's what I'm running right now.
As far as drivability goes I used to have an RX8 and the C 63 is way more drivable in winter. Probably because it's much more heavy. If you do get you rear on some wet ice even on a few degree of incline your not going anywhere unless you have some studded tires. But any other rear wheel drive car wouldn't fare much better I guess.
As far as looks go for the 225 tires in the rear, i guess it does look kinda funny but only seen from the back of the car. When you look at the car from the side, if you have the proper offset for your wheels the tires fit just right with the fenders like the OE wheels so it actually looks A OK.
