Upgrading my Brakes!
Or just use the PCCB from your P car j/k
I think that Carbon Composite brakes are not that practical for every day use. Warming them up, avoiding fast temp change (ex: rain).
My own opinion, is to upgrade brake lines (SS) and get some "racing" braking fluid, maybe getting Evosport Rotors is a good way as well (I think they are coming out with a set for the front axle as well ) Less weight + More ventilation = GOOD
May I ask what kind of brake lines are you running and what type of fluid.
I remember you had a thread on this matter about half a year go. (Something about how to bleed the brakes if I recall correctly)
If you feel some fade with good pads and fluid then I would recommend aftermarket lines, I know Evo sport sells some. If anyone has feedback on them please post it.
cya
Carbothech makes pads for our car and offers a choice of 5 or six different compounds.
My 2 piece rear rotors are from Evosport and the fronts are stock AMG PP 2 piece units.
Honestly, I would only do a lighter set of rotors, that is always beneficial(better acceleration, better gas mileage, less weight,better braking, better cooling, etc).
I personally have no intentions to upgrade the brakes, you can't really get much bigger than the stockers and if you do they wouldn't make much of a difference. The pads can make a difference but again I consider the stock C63 brakes to be plenty of braking power, they also modulate the braking very well...
