C63 AMG (W204) 2008 - 2015
Aftermarket wheel Thread.
Old Nov 10, 2013 | 09:09 PM
  #1551
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Wow, I just noticed the sideskirts & rear skirts .. Perfect combo with the front lip!! Good job mike888
Old Nov 11, 2013 | 03:54 PM
  #1552
drcbc's Avatar
C63 2012 Coupe
Cracked Forgestar F14 wheels, three out of four!
3 out of 4 Forgestar F14 Wheels cracked. Wanted to document my experience with aftermarket Forgester F14 Wheels on a 2012 C63 P31. Car was leased in Dec 2011 and 18in Forgester F14 wheels purchased with Vredestine Tires in Jan 2012 from an aftermarket dealer in Las Vegas. A black powdercoat was applied before tires were mounted on the wheels by another vendor in Las Vegas. I assumed the lease in Jul 2012 and the car was transferred to San Antonio.
In Dec 2012, Inoticed a leak in the passenger front tire and had it inspected at a local Firestone dealer. They found a hairline crack on the inner lip, showed it to me and said they had someone who could weld the crack. I did not take a picture. After several weeks it was decided that it could not be repaired and a replacement was ordered from the Las Vegas dealer where the wheels were originally bought. The wheel plus the powder coating cost close to $800 and was delivered to me about 4 months later in May 2013. Things were fine until July 2013 when I noted a leak in the driver front tire. I took it to the Mercedes Dealer who found another crack on the inner lip of this wheel and sent it out for welding. The weld worked for several months but a slow leak was noted and the day I took it in for inspection, a leak was noted in the passenger rear tire. Both wheels were inspected and there was a new crack next to the welded area and the passenger rear wheel also had a crack on the inner lip. See attached pictures. Fortunately, I have the OEM wheels and tires so they are back on the car.
I have been driving the same 7 mile home to work path over“friendly roads” for 30 years with about 10 different cars. I have had my shareof flat tires but never a problem with a wheel cracking. Most of these cars didnot have low profile tires, but my last car was an E350 and the OEM wheels andtires never had problems. I did hit something hard enough to bend one of theE350 wheels and damage the sidewall of the tire. The tire was replaced, the wheel was beatback in shape but there wasn’t a crack.
Attached Thumbnails Aftermarket wheel Thread.-driver-front-forgesterf14-weld-crack.jpg   Aftermarket wheel Thread.-pass-rear-forgesterf14-crack.jpg
Old Nov 11, 2013 | 05:56 PM
  #1553
Roswell's Avatar
Sorry to hear about ur misfortune drcbc, Forgestar are overrated wheels made in China therefore the cheap cost. Some ppl had good luck with their wheels & customer service, some like u just had nightmare.
On the other hand, was ur wheels powder coated by a different source other than Forgestar? I'm asking cuz a bad powder coating process can definitely weaken the wheels structure.
Old Nov 11, 2013 | 06:22 PM
  #1554
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Prior to ordering Forgestar CF10s I did a fair amount of internet searching. It seems that the F14 has either an inherent design issue or regularly undergoes a mnufacturing issue as the reports of failure are numerous. The reports of failure in respect to Forgestar wheels other than the F14 are rare. You would have thought that by now Forgestar would have fixed the issue (I note that drcbc's wheels date back to Jan 2012) given they have been around since 2008/2009.
There is a market out there for someone to produce mid range priced wheels out of China with quality and service.
Old Nov 11, 2013 | 07:15 PM
  #1555
bhamg's Avatar
C63 AMG
That's the thing…when you take an inexpensive non-forged wheel from offshore that weighs under 20lbs in 19x8.5 and then powder coat it again at anywhere between 400-1,000˚F…well that's asking for (structural) trouble IMO.
Old Nov 11, 2013 | 07:25 PM
  #1556
drcbc's Avatar
C63 2012 Coupe
Yes Roswell, the black powder coat was done by someone other than Forgestar.
Old Nov 11, 2013 | 07:32 PM
  #1557
Roswell's Avatar
That "might" be the cause of ur cracking drcbc. I'm not taking the blame away from Forgestar, but the powder coating process might have something to do with this.
I would say those wheels are good for recycling, they are a ticking bomb. Buy a nice set of forged wheels & don't look back. Good luck!
Old Nov 11, 2013 | 07:43 PM
  #1558
mike888's Avatar
C63 S204
Thanks!
Old Nov 11, 2013 | 09:35 PM
  #1559
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Lots of ppl rubs but don't kiss & tell lol
Seriously, I agree with u.. I find it very strange when ppl post they are running (for example) 19x10 +48 or +50 w/275/30 w/o rubbing.
I can't even get away with 19x9.5 +50 & 275/30. All is good with 265/30 now.
The V12 275 you were running has a wide section width of 10.9" and same goes for their 265 which is a 10.7" section width.
I'm going to chance the 275 AD08 R (10.7" section width) on a 9.5" +50
Old Nov 12, 2013 | 07:24 AM
  #1560
Roswell's Avatar
Good infos jasonoff. I don't rub with the 265/30 V12 (10.7" as u stated), so if ur math is good u should be fine with the 275/30 AD08 R.. Are those Bridgestone?
Old Nov 12, 2013 | 02:47 PM
  #1561
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
AD08 R are Yokos. I'm considering a 10" +55 now. Math still checks out.
I run a 14mm spacer on the OE rear which makes it a 9" +40 that rubs with people in the back or on the track. That translates to +52.7mm on a 10" wheel.
I think, err hope the extra 2.3mm will make it clear.
Old Nov 12, 2013 | 06:56 PM
  #1562
Roswell's Avatar
Definitely 19x10 +55mm w/275/30/19 will clear. I think with that offset, u can go 285/30/19.
Yokos Advan sport is what I'm running on my oem multispokes, and they look bulgy (19x9 w/255/30/19) and seems to run wider than my V12. Maybe the AD08 R are different.
What wheels are u getting? Sounds like custom made wheels since u can chose the size & offset.
Old Nov 12, 2013 | 09:34 PM
  #1563
Stefj's Avatar
Mercedes c63 amg
Thats funny cause m'y car i have the amg king of avs f15 gunmetal on 19 inch andd 3 of 4 are been crack, for sure I did track but this is not the case, the suspension is so tight that was the cause, don't blame on a particular brand this is the car effect by is weight plus suspension setup
Old Nov 12, 2013 | 09:51 PM
  #1564
ed4's Avatar
ed4
2010 Audi S4, 2013 MB C63
WTF language is that?
Old Nov 12, 2013 | 10:01 PM
  #1565
Roswell's Avatar
LOL, not everyone is fluent in English including myself.
But I think he meant his AMG multispokes (looks like the ADVAN F15) cracked as well, so no matter what brand wheels (reference to the Forgestar post above) the set-up of our cars made it more prone to cracking wheels.
In my opinion, not really true cuz the multispokes are also known for cracking issues. Not normal & AMG should honor this defect like the headbolts but they prefer to ignore the problems.
Old Nov 12, 2013 | 10:11 PM
  #1566
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I'm pretty sure he used his phone to post
Old Nov 13, 2013 | 07:57 AM
  #1567
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Don't put any ideas in my head
Old Nov 13, 2013 | 06:22 PM
  #1568
RNS-11Z's Avatar
09 C63
More pics to come. Absolutely love the new look. Better photos next week
Old Nov 13, 2013 | 07:56 PM
  #1569
Roswell's Avatar
Dooooooooo iiiiiiiiiiiiiiiiT! Lol
Old Nov 23, 2013 | 12:10 PM
  #1570
Dragonov Costa's Avatar
C63 AMG
Just to add to the topic of Forgestar wheels, and their manufacturing quality, I have had 3 bent wheels this summer alone. In June I bent 3 wheels, didn't see that the rears were bent and only got one front wheel fixed. I hit an unpaved transition so hard that it had knocked out the alignment. The rear tires wore off the inner walls and further bent the wheels on the inside lip. When I got the rear tires replaced at the dealer, they saw the bends, and I now I have two more wheels on order from Eric at getyourwheels.com. Good thing I have USAA insurance and they picked up the tab and are suing the paving company.
Old Nov 24, 2013 | 06:03 PM
  #1571
BerBer63's Avatar
2009 C63
I got an extra F14 if any one needs it. Never installed. See my sig
Old Nov 24, 2013 | 11:09 PM
  #1572
Stefj's Avatar
Mercedes c63 amg
I definitively write with my phone, sorry for this. I just decide to stop buyer expansive wheel for a cheaper but still forge wheel, Mandrus... someone have a issue with Mandrus ??
Old Jan 15, 2014 | 11:43 AM
  #1573
b7bydesign's Avatar
'11 BMW E90 M3
After some searching, this seems like the best place to post fitment related questions. Can anyone confirm if this setup would fit a '12 C63 sedan? As a note, I plan on going pretty low with coils.
Front - 20x9 ET35
Rear - 20x10 ET40
From what I've been able to gather, my offsets may be a little too low and I'm about .5" wider F&R than most of the fitment in this thread, just looking for a confirmation or second opinion. Thanks in advance guys!
Old Jan 15, 2014 | 12:25 PM
  #1574
Roswell's Avatar
The front can fit with stretched tires (235/35 or 225/35), but the rear will be a pain. U need at least +50 to clear the 20x10.
Old Jan 15, 2014 | 01:08 PM
  #1575
b7bydesign's Avatar
'11 BMW E90 M3
Appreciate the quick reply!
