My C63 Dyno Results
Very interesting..... initial hp readings seem lower than usual while torque numbers seem higher than usual Nice gains however....
I don’t think the dyno operator did you any favors. Your max torque is at 4000RPM. My max was south of 5200rpm. It looks like they brought the car up to 3600rpm and floored it. This will not give you much to go by. I would think you would need to bring the car to 2000RPM or so and let the car shift at the redline for the next three shifts. Peddle on the floor at 5-6 gear. Not allowing the car to downshift once you apply peddle. Your torque was very high in my opinion but it was very short lived. The HP looks low to me. Mine was 415 peak. I believe you would get a different result if the dyno was done differently. Your before run looks very low. Under 300hp but your after number is around 360hp. The positive note is your gains. 60HP is a good thing on any graph. Just remember numbers are just numbers..
Just my two cents.
Just my two cents.
Thankfully the good response to affection as mere numbers, "said my brother TEXC63
MB_Forever I would like to thank you especially for your response and I want you served him well on the car and provide the best exhaust can be used
