Vredestein Ultrac Sessanta
Front 19X8.5: 23 pounds
Back 19X10: 25 pounds
This was done using a human scale, not an high end electronic one so I can't guarantee the accuracy. The wheels do feel very light.
Here is the official weight from modbargains.com:
19x8.5 Approx weight 22.5 lbs
19x10. Approx weight 24.7 lbs (site says 24.1 but I think they mixed up some numbers)
Both wheels are still lighter than the stock 18" (at 23.5/front and 25.0/back).
For 19" that's pretty impressive.
As a comparison the HRE P43 19x10 are 24.6 pounds and 6000$ per set!
Thanks for weighing the wheels, looks like they are fairly light.
Different offsets certainly impact final weight, since they remove back-padding to get to the final offset. Higher offsets should weigh the least.
I ordered my Gun Metal 18's today! (18x8.5 ET46, 18x9.5 ET55)
The stock wheel weight I found on the board if I'm correct. I remember that I searched for a long time =)
I don't even have my car yet (picking it up mid march) and I already have the wheels and a KW v3 suspension. I'll probably get them installed mi april after the break in period because I want to ride the car hard before I make the upgrades.
I'm hoping the stock 18's are bit heavier. I remember Josh weighing his set when he upgraded to HRE 19's. His quote was 26lbs front and 26.5lbs rear w/o TPMS. (Post here -> https://mbworld.org/forums/3435781-post15.html)
I'm hoping he's right.
Good luck with everything!
245/35-19 = 26 lbs
275/30-19 = 28 lbs
So fairly standard tire weights, maybe a little heavy.
My rims are still on the way but being delivered soon. I just wanted to know if these are going to fit the C63? I can't see that anything larger would fit based on the measurements I took in the wheel well.
Just ordered the F14 in matte black, 040 black c63, 18 x 8.5/9.5 w/ hankook v12 in 245/275. I really need the extra grip w/ the K1.
What you'll find is 275/18/35 but they will look a bit bubbly (thick).
Anyway, talking with Forgestar over email, they say that 275 will not fit in the rear without serious fender mods. Designo posted some pics of a black on gold C63 and Forgestar has said they did some rolling and pulling to get the 275 to fit.
I want to go 245 / 275, but I think I will end up with 235 / 265 based on what Forgestar has said.
A 275 will fit perfectly on a wheel with the right width/offset.
