Upgrading ECU?????
Warranty? Yes if you blow up your engine and they decide to blame it on the 50 more HP from the ECU flash. No if the dealer is cool. Some dealerships I hear do the flash at the dealer shop. Still a risk, but at least you can say you didnt know because they did it.
Also, if you have a serious problem, have your ECU flashed back to stock before you take it in...it is a 3-day process ($100) but will save you a lot of money in the long run if the dealer proves it was the ECUs fault.
The only way they can tell is if they run StarDiag on the car...and even then it won't tell them much. Where you will get into trouble is with hardware mods, as removing cats or swapping headers will be easy to see and hard to change before going in (and will cost a lot more money to make right before you go in).
A shelf ECU tune is the easiest/cheapest/quickest HP gainer there is
