car starting issues
I eventually figured out it only happened when the car was parked in direct sunlight. In the shade or first thing in the morning it never failed. I think something in the ignition switch warped from the change in temperature. However, the dealer did a warranty replacement with a new ignition switch and it has NEVER failed to start since then.
I hope this helps.
the key switch didn't work. this weekend it happened to me 4-5 times with the other key. and i don't have to turn it all the way left, just one notch left and then back to the right again to start it up.
everytime I turm off the car to put gas or do something and leave the key on the ignition or take the key but dont close the door.... i
it could be a security thing... I dont know I just learned to live with it
As soon as they changed the EIS (on warranty of course) I've never ever had the problem again. I also changed keys at first and thought all was okay but it re-occured later on and that's when I saw the link to the hot weather. Regardless, the EIS is what can cause all these problems otherwise it will be a problem with the wiring harness somewhere.
Ask them to change the EIS and tell them another C63 owner had a very similar problem and that was the solution. After all they are having problems identifying the source. The EIS is responsible for giving the engine control unit the go ahead to start the car. Good luck.
