C63 AMG (W204) 2008 - 2015
2009 C63 Kleeman K1 Dyno
Old Aug 10, 2010 | 04:11 PM
RStevens63's Avatar
E63
Keep in mind that the carbonio foam filters are known for being over saturated with oil. You may have to clean the MAFs again after installing. Just fyi.
Old Aug 10, 2010 | 04:14 PM
Even Money's Avatar
'15 VW GTI
Thanks..that's what I've been told..
Old Aug 10, 2010 | 05:36 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
If you ask Wayne, he'll let you know that a few months ago he ordered a euro air box that was used, and had a bad or dirty maf, once he put the maf's that he had from his factory airbox his power was back up.
i'd try the dyno run honestly with the stock paper filters, unless you got the new carbonio filters which are now oil-less filters.
Keep me in the loop Will.
James@ACG
Old Aug 10, 2010 | 05:44 PM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
James@ACG
Yep. I think I called James at least 3 times within one hour.
Once I put the original MAFs back in my consistent power curves were back.
Also worth noting that avengerboater and I have tried various filters and none made any more or less power on the dyno. Avenger still runs paper filters because of this.
Old Aug 10, 2010 | 05:51 PM
Even Money's Avatar
'15 VW GTI
Will keep you advised James, and thanks for all the help. Copy on the filters, but I thought it was worth a shot...maybe my stock filter's bad. These carbonio foam filters, I think they are the oiled ones, seem to be made by pipercross(although they wouldn't confirm that on the phone). They had a really good rep, so what the hell??
We'll know Sat. about 0945!!
Now all I need is a deal on some ADV wheels...
Old Aug 10, 2010 | 08:17 PM
avengerboater's Avatar
C63 AMG
Yup. At least we weren't able to see any gains on the dyno with the k&n and carbonio filters compared to stock filters. Now, will there be any noticeable improvements on the streets or drags with 100+mph wind...who knows?
Old Aug 12, 2010 | 09:21 PM
  #32
Raleighc63's Avatar
2009 C63
Even Money - It seems fairly common from others on this forum but I'm just wondering why did you get a Kleeman Tune knowing that you were waiting on MHP Headers? Am I missing something??????
You obviously think that the MHP TLH's are better than others so why not go with the tune as well?
BTW - Cory told me the same thing he told you after I originally got my tune from them however the dyno results (delta's) don't lie. My delta with Kleeman
Is your 1/4 mile time stock or was that with the Kleeman tune?
Old Aug 12, 2010 | 09:29 PM
  #33
Even Money's Avatar
'15 VW GTI
^I got the K1 tune back in February, long before I thought I was getting the LTs. I'm going to try the K2 file, and may eventually get the MHP v3. The 1/4 mile was with the K1 tune, 406 whp on the local dynojet. I don't have a delta as I started with a mustang dyno that has since broken. So, I only have the after. But, based on what others with the same tune are getting on the same dyno, I'm about 15 whp short....so hence cleaning the MAF and trying the foam filters...If after getting the LTs and w/ the K2 file..if still not happy, then I'll try the MHP v3.
Old Aug 13, 2010 | 10:25 AM
  #34
Sincity's Avatar
^ I don have a baseline either. But you do seem about 15 WHP short. I did 421/384 with 70 degree temps and 9% humidity. Those numbers are with ROW box tops and K&Ns (if that made difference).
Old Aug 13, 2010 | 11:47 AM
  #35
Like EM mentioned, two other cars on the exact same dyno with the same Kleemann tune dyno'd between 422 RWHP and 426 RWHP.
Not a huge variance but enough that we've been scratching our heads. We've had six different C63s on this dynojet (A MHP-tuned car, a evosport-tuned car, three Kleemann-tuned cars and one P31 car). All of these cars came in as expected except for EM's car.
Old Aug 13, 2010 | 12:16 PM
  #36
Sincity's Avatar
Perhaps it has something to do with break-in? Cory told me to hammer (not my intention to start a break-in debate) the car from the day I got it.
Old Aug 13, 2010 | 12:38 PM
  #37
Even Money's Avatar
'15 VW GTI
I didn't baby it during brea in. Varied rpms w wot every so often.
Old Aug 13, 2010 | 12:50 PM
  #38
avenger and I put that to the test. I babied my car, he beat on his during break-in. Our peak HP difference was less than 1%. Myth debunked.
Old Aug 13, 2010 | 05:26 PM
  #39
C63 AMG
Old Aug 13, 2010 | 06:06 PM
  #40
Sincity's Avatar
Old Aug 13, 2010 | 07:57 PM
  #41
Even Money's Avatar
'15 VW GTI
New Carbonio foam filter
Carbonio foam filter, $80 each, just arrived. These are their new design, NOT oiled. As you can see, there are three layers of foam. The guy on the phone said they switched to dry foam due to customer feedback/complaints about oiled MAFs, etc. He said they work just as well. So, we'll see tomorrow am! You can get these from carbonio direct. Shipping is free, unless you want it faster.
Old Aug 13, 2010 | 08:06 PM
  #42
Sincity's Avatar
To clean, do you just soak it in a solution of Simple Green?
Old Aug 13, 2010 | 08:16 PM
  #43
Even Money's Avatar
'15 VW GTI
I think just soap and water...then dry.
Old Aug 14, 2010 | 12:38 AM
  #44
Hans Delbruck's Avatar
What I like!
Originally Posted by Even Money
I recall when Cek's car was on the dyno..took out the charcoal filters, and lost about 5 to 10 whp if I recall correctly.
edit: never mind, he has P31!
Wonder if there is any more dyno data about losing HP with the charcoals removed.....
Old Aug 14, 2010 | 12:04 PM
  #45
cek's Avatar
cek
'10 C63 AMG P31, '88 Porsche 911 Carrera Coupe, '78 Toyota FJ40, '10 Audi Q7 TDi
Either way, the actual results with charcoals removed on my P31 car were:
-4.79 (-1%) RWHP / -2.33 (0%) RWTQ (using average across 3 runs)
Given the number of variables involved with doing dyno stuff +/-1% gain/loss is noise. Arguing, based on my numbers, that charcoals make a difference one way or another is without merit.
Old Aug 14, 2010 | 12:05 PM
  #46
cek's Avatar
cek
I babied my P31 and it's clearly pulling VERY healthily. Further debunking the myth.
Old Aug 14, 2010 | 01:17 PM
  #47
Agree 100%.
You are also only using peak #'s too. In looking at your graphs without charcoals, you didn't have that same little spike at 6700-6900 RPM that you had when the charcoals were in place. There were even some places in the mid range that you made more power without charcoals.
Fun stuff.
Old Aug 14, 2010 | 01:37 PM
  #48
GHAZAN's Avatar
MBUSA
New dyno today? I'm going to guess <6rwhp difference, no significant change.
Old Aug 14, 2010 | 01:50 PM
  #49
Even Money's Avatar
'15 VW GTI
On my iPhone. Will post graph later. Bottom line, nothing changed!! Must be the ecu, don't know what else it would be....if there was an issue. You'll be able to see from the graph that the ecu appears to pull timing a bit at 4100 and 4500 rpm, also the plot is jumpy compared to others I've seen on same dyno,tune. If not for the anomaly at 4100 rpm the curve should trace to about 420 whp, vice the 405 I got. Did 5runs all very close together. Same type fuel Afr was low 12s. I would try a reflash at this point, were I not getting LTs and anew tune in about three weeks. So after the header install hopefully the new kleeman tune will fix things.
Oh, and I know how toclean the mafs now.
Old Aug 14, 2010 | 02:49 PM
  #50
Oh, and I know how to clean the mafs now.
The other explanation (and I hate to say this) is your car may simply not be as strong as others. You could be chasing a ghost.
