M mode disappeared while on the track
2009 C63 AMG
I was at the track yesterday driving very hard and on my 3rd session on the second to last lap the car switched to sport mode on it's own and took away the option for me to put it back in manual mode. When I finished the session I turned off the car let it set and now the Manual mode is back.
Any ideas? Has anyone experienced this?
Thanks for the help.
2009 C63 AMG
I don't know. Thinking I might have broke something, I took a semi light lap then brought it in. It was shifting at mostly the right points though but you don't have the same control.
I am going to call Mercedes tomorow morning but wanted to post here in hopes that someone has experienced this already and/or might know what the cause could be.
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
Perfectly normal, on my track sessions this has happened when the tranny seems to get a little hot, other members here who track their car have experienced the same thing. There is no harm done, when the car cools off a bit then all is back to normal.
2009 C63 AMG
Really? Well that's a little disheartening. There should be a way to direct more air or use a better transmission fluid to keep it cool. I hope to track the car more often and for longer seasons and definately don't want this to be occuring.
Im gonna see what I can find out and will post it here.
Thanks for the confirmation that I didn't break my car.
1 Post
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Agreed - I had the same thing happen in my Black Series at Willow Springs on a VERY hot day (115 degrees). When it happened I was in the middle of turn 8 well into triple digit speeds holding a tight line in 5th gear and all of a sudden the trans goes into C mode and upshifts to 7th sending the car sideways and drifting into turn 9...Not fun at all and could have turned into a huge off.
2009 C63 AMG
Yes this seems like a pretty big risk especially since there is no warning.
It doesn't appear to be oil temp related but transmission temp. It wasn't limp mode as the car contined to shift in sport mode and their didn't appear to be a drop in power.
It's really frustrating and a little scarry that this can happen at any moment. I going to call Mercedes and get to the bottom of this.
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
I remember a thread a couple months back about an extra available heat sink either on the transmission or somewhere around there. Maybe those that seriously track their cars would be willing to go through the moderate time investment to add an extra heat sink on.
1 Post
2010 C63
You may be thinking of the rear diff, which has a heat sink / fins for factory LSD units.
2009 C63 AMG
2002 S430, 2004 Cobra, 2004 Tahoe
I have to agree with you guys that the potential for something hazardous is out there, but you have to step in to MB's shoes for a moment. It is a fail safe mechanism probably for warranty purposes. If it's triggered to come on at a certain temp, then that means that is probably the limit of the trans and it doesnt want you to go over that.
2009 C63 AMG
It's a known issue. Read the last 2 paragraphs on this article.
http://www.carracing.com/CarReviews/...html?s=driving
My point is there has to be something we can do to keep it cool and that is what I am going to look into.
02 CLK 55 AMG,09 C63 loaded with P30
I wonder if AMG fiddles with the AMG Academy cars to address this problem somehow - the instructors do hot laps in the Cs, and I would think that they would be comparable to most of the guys that track their cars on this forum.
2010 C63
I believe the car already has a transmission cooler. As LZH says, it should be pretty easy to upgrade it.
If you really wanted to do it right, though, you could probably put an extra tranny cooler into the left bottom bumper cover with a fan, and cut out those fake air vents to work like they do on the right (where an engine oil cooler lives).
Tranny switching under hard-driving is not a good thing...it should NOT happen on its own...and if it does, it should go to "S" mode....
I hate that you have to go through C to get from M to S anyway. Seems to me that it should go M, S then C...as most people that are driving in M mode that want to switch don't want to go through C. In fact, you should have to push and hold to get C.
1 Post
I would say that when my transmission kicked me out of M mode, I wasn't too surprised...it was very hot as I mentioned before, and I only know of a few other street legal cars that could have gone as long as I did without overheating something in those conditions. IIRC the track temp was in the 130's....So, I guess my point is that it's no wonder the C63's are having the same issues under even more favorable conditions as they are not setup to take the abuse that the Black Series can handle. Again, someone should looking into putting the CLK Black Series transmission cooler setup in to the C63. Im sure it would be an easy intall and you'd have all factory parts - the only thing I could see being an issue is fitment and space. You would probably have to have a few brackets custom made and perhaps move a few lines around.
To the OP - what was the ambient temp while you were running ? You cannot just "get more airflow" or use another trans fluid to keep this from happening. If you do plan on tracking your car more you REALLY need a larger transmission cooler or an additional one installed in the left bottom bumper cover as ATL MB suggested. If there is space there, that's what you should do.
Something like this:
http://www.streetperformance.com/par...-db-30216.html
Also, if your car has an ECU tune AND you are planning on headers and a pulley...I'd strongly suggest going with an additional trans cooler. Take a look at ths thread and you will see what I mean:
https://mbworld.org/forums/c63-amg-w...mea-culpa.html
