10" Rear rim
To be honest i've only had 2 women in the back of car at the same time and the tires were the only things that didn't rub
You're gonna need 10 bolts that are 60 degree tapered. they are 17mm head with a 14x1.5 thread. They should be 35mm to 36mm in length.
10 x Bolt | 14 X 1.5 | 35mm | Tapered (60 deg.) | 17mm (1453501)
FYI....your factory lock nut will not work on the front wheels as it will be too short as well (that's why i said get 10 of them)
Just remember that my car is stock P30 suspension and if your car is lowered then 10mm spacers might be to aggressive and rub....but on my set-up it's perfect
