straight pipes
A good tune like Kleeman, Asura/Singh, MHP etc., will solve that issue. Also, if you use our 2nd cat X-pipe you will not throw a CEL as the ECU will not detect it, but if you remove the main cats, you WILL get a CEL. our new LT header design will not cause a CEL either due to it's design as well.
now the the theory of the double x-pipe is tying to create turbulence so you get back pressure hence more power and torque through out the power band.
but you have to notice the double x-pipe is a very nice design. for a stock ecu set up and is maybe better for most users. (I think)
if you going to go for bigger HP in the future I think it is better for you to go bigger in diameter on the exhaust pipping like 3'' or 2.75''
1. So you don't need a reflash? I thought you needed one to take advantage of the increased exhaust flow, but are you saying that the ECU would adequately adapt?
2. When do you expect some dyno results?
3. When do you expect these to be able to ship?
Thanks!
