C63 AMG (W204) 2008 - 2015
paint help
Old Apr 19, 2010 | 08:14 PM
dmyrick's Avatar
C63
paint help
I picked up some small white flecks of road paint on the right lower body of my car can anyone tell me how to get them off?
Old Apr 19, 2010 | 08:32 PM
blackc230benzo's Avatar
2010 C63, 2003 C230 coupe
I would try a clay bar and lubricant first. If that doesn't work try hand buffing with an applicator pad and a light scratch or swirl remover. A buffer would work too but just make sure you know how to use them.
Old Apr 19, 2010 | 11:07 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Indeed, lubricant, WD40 or this stuff:
Try buffing over and over, then ultimatley use clay bar to smooth.
You are essentially "lifting" it off the clear coat. DO NOT USE THINNER, but you may use rubbing alcohol to try to dry it and flick it off as well...
Old Apr 19, 2010 | 11:28 PM
Sincity's Avatar
How about road tar remover?
Old Apr 19, 2010 | 11:35 PM
ZephyrAMG's Avatar
Could work, but the paint is not sticky. That tar remover is for heavy duty sticky stuff and he could end up encorporating the paint further into the clear coat. The paint has attached its self to the primer. What he needs to do is hope to either get a lubricant to get between the paint and the clear coat to loosen it up or to dry it and then flick it off of the "wetter" clear coat.
Old Apr 20, 2010 | 01:53 AM
Even Money's Avatar
'15 VW GTI
Try a clay bar. If that doesn't work, find a reputable body shop. You can easily screw up your paint if you don't know what you're doing with a buffer, in which case you would have to go to a body shop anyhow...
