C63 AMG (W204) 2008 - 2015
Lifting the car
Old May 5, 2010 | 11:57 AM
PatSC23's Avatar
2009 C63
Lifting the car
Whats the best/safest place to use to jack up the rear of the C63?
Old May 5, 2010 | 12:15 PM
DFW01E55's Avatar
'14 ML BT
At the jack point in front of the rear wheel.
It will pull one side off the ground, not the rear end.
To get the rear up, get a pair of ramps and back up onto them.
Old May 5, 2010 | 01:15 PM
bhamg's Avatar
C63 AMG
If you are the type that tends to get under your car more often than most, consider these:
https://mbworld.org/forums/c63-amg-w...-jack-pad.html
Old May 6, 2010 | 03:38 PM
ATL_MB's Avatar
2010 C63
I am interested in this question as well. I have used the differential housing to jack the rear of my and my wife's W203's without any ill effects, but it does make me nervous every time I do it. Looking at the differential housing on my C63, I would think it is probably OK to lift it there, but I don't want to be the first to try it (and I might not ever try it if I had a factory LSD with the finned diff cover). The diff is not part of the suspension and seems to be pretty well locked into the rear subframe at both the front and back, so I think it is OK, but still. . .
OP - why don't you try using the diff cover, and let us know how it goes?
Old May 6, 2010 | 03:46 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
if you're doing rear, parking brake and wedge the front to prevent roll. I wouldn't keep it on the supplied cross jacks for anything more than quick wheel swap. Get a quality jack with rollers to keep it from tilting over.
