C63 AMG (W204) 2008 - 2015
Photos :: Nitto NT555R Drag Radials (285/35-18) :: 2010 C63
Old 05-15-2010, 04:06 PM
Super Moderator Alumni
superlubricity's Avatar
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
I've replaced the original rear tires with Nitto's NT555R Drag Radial (285/35-18).
These tires are really designed for dragstip use. They are R-compound tires (very soft and sticky) and they provide maximum traction to the drive wheels. This will essentially prevent wheelspin at launch and help get the 60' and ET down significantly. In my opinion, this is one of the most essential mods for those looking for the best and most consistent results at the strip.
You can read more about these tires here -> http://www.nittotire.com/#index.tire.nt555r
For this application they are a little tall @ 25.91" diameter and they are a little fat @ 11.22" wide but man do these suckers hook. The difference is night and day. It's nice to finally get my 446 RWHP to the ground! These tires + the Quafie LSD = Traction Heaven.
So far there have been no issues with rubbing.
Note: I haven't tried any extreme angled declines or inclines nor have I loaded the backseat with passengers. Take my "no rubbing" with a grain of salt.
I've run Nitto DRs on more powerful vehicles in the past with great success. Just as before these are very streetable and even manageable in the rain. The sidewalls are soft so aggressive handling/cornering is not encouraged. One benefit to the soft sidewall is that these only weigh approx. 25-lbs each.
They will eventually become my dragstrip-only tires. I'm still waiting on my Forgestar F14 wheels (18x8.5 ET44, 18x9.5 ET53) and will be running Nitto NT05 tires (245/40-18, 275/35-18) on them.
Here are the photos:
Close-ups:
Glamour shots:
Old 05-15-2010, 04:13 PM
alqamzi's Avatar
2009 c63, 2011 GT500
Thank you very much for the review...now i know wich drag radials i will get.
Old 05-15-2010, 04:17 PM
BerBer63's Avatar
2009 C63
Awesome, now you need some coilovers to finish it off
Old 05-15-2010, 04:33 PM
_AMG_'s Avatar
C63
WOW those look awsome, I was goin nuts trying to figure out if i could put 285's on stock wheels, now i know its possible .
Old 05-15-2010, 04:38 PM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
Mmmmmmm, very nice indeed.
Old 05-15-2010, 04:41 PM
My pleasure.
I'm thinking about it.
I certainly would not recommend a 285 if a 275 was available. This was the only way to get the tire I wanted. Really only one choice.
Besides, not all 285-width tires are equal. Get the exact tire width and diameter from the manufacturer before assuming it will fit. Some tires are notoriously wide.
Old 05-15-2010, 04:58 PM
avengerboater's Avatar
C63 AMG
I like fat and sticky tires...among other things. Good job, superlube!
Old 05-15-2010, 05:08 PM
_AMG_'s Avatar
C63
Originally Posted by superlubricity
My pleasure.
I agree. I know Michellins and Continentals usually run wider. But those 285's you have look great.
Old 05-15-2010, 05:33 PM
callmiro's Avatar
2016 C63 S
That's awesome...dispells all the ney-sayers postings that you can't fit a 285 on a stock wheel
You're gonna hook like nails outta the bucket now
Old 05-16-2010, 12:02 AM
C63newdude's Avatar
C63 AMG
Finally someone with big Cojones (*****). Thanks for being pioneer on this and rolling the dices, I will soon follow you on that same exact set up. Too bad we are on 9" in the rears but I rather have traction than anything else.
I am currently running 275/35/18 Nitto NT 555 Extreme ZR but they are like 300 threadwear. It improved my traction but I think my car needs like 285 despite being almost stock power wise.
Thanks for the pictures, looks sick!
Old 05-16-2010, 12:11 AM
Thanks, but I can't claim the pioneer title. The folks at RennTech, DadsC63, Andy@MHP and some others have used this setup on their C63 with a lot of success.
Old 05-16-2010, 12:13 AM
C63newdude's Avatar
C63 AMG
Oh well, I guess I missed those post. Changing the subject, I dropped 100 rpm on 7th gear cruisng at 75mph, I am now at 2000 rpm compared to 2100rom when I had my oem tires. I am sure you dropped even more rpms(even taller gearing).
How much a set of those ran? Our cars should had come from factory with decent 9.5" or 10" don't you think?
Old 05-16-2010, 01:44 AM
C63fan's Avatar
C63 w/p30; MHP ECU tune+header+mids+CF air intake duct+Akrapovic+wide body kit+ Vorsteiner VS110
My pleasure.
That looks great and it's so encouaging to have wilder tires!
Is there 285/30/18 available from Nitto? 285/30/18 is 1.2% smaller than stock and 285/35/18 is 3.3% larger than stock. So, 285/30/18 should be a easy upgrade with more direct road feedback plus less chance for rubbing! Is there any other concern?
Old 05-16-2010, 10:49 AM
No, not in a Drag Radial tire.
Old 05-16-2010, 10:55 AM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
How come you are running different front tires?
Old 05-16-2010, 11:04 AM
I've replaced the original rear tires with tires designed for the dragstip. These are R-compound tires (very soft and sticky) and they are designed to provide maximum traction to the drive wheels. This will essentially prevent wheelspin at launch and help get the 60' and ETs down. In my opinion, this is one of the most essential mods for those looking for the best and most consistent results at the strip.
Eventually, I'll be using a completely different wheel/tire combo for everyday use and when I road race (see my signature for details).
I've added this info to the first post.
Old 05-16-2010, 11:16 AM
gsrjc's Avatar
I've replaced the original rear tires with tires designed for the dragstip. These are R-compound tires (very soft and sticky) and they are designed to provide maximum traction to the drive wheels. This will essentially prevent wheelspin at launch and help get the 60' and ET times down. In my opinion, this is one of the most essential mods for those looking for the best and most consistent results at the strip.
When I road race, I'll be using a completely different wheel/tire combo (see my signature).
Oh I see.
Old 05-16-2010, 03:28 PM
C63newdude's Avatar
C63 AMG
I do too. As long as one full axle has the same tires you should be OK.
Old 05-16-2010, 03:38 PM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
Those looks sick man! 285's look mean on stockers. I see in the future you're looking at NT05's.. If you like the 555's you're gonna love those
Nitto FTW.
Old 05-16-2010, 04:03 PM
Former Vendor of MBWorld
Brian GT PRO's Avatar
C63 AMG Arctic w/ Stage 1 Tune, DoubleXX pipe, MCD-631X coming soon
Gotta love the FATTYS NICE!!
Old 05-16-2010, 08:52 PM
Old 05-17-2010, 12:17 PM
Originally Posted by tgoss
Those looks sick man!.
They've got the look and they sure do hook!
Cheesy . . . I know.
Old 05-17-2010, 04:55 PM
C63 AMG
Old 05-17-2010, 05:57 PM
Originally Posted by avengerboater
Ha, I deserved that.
BTW, I just emailed every drag strip in OR and WA state about a Private Track rental . . . stay tuned.
Old 05-18-2010, 12:29 AM
C63 AMG
Sah-weeeet!!!
Quick Reply: Photos :: Nitto NT555R Drag Radials (285/35-18) :: 2010 C63
