6.3 amg stroker kit?????
That was my point for bumping this thread although this thread should be in W211 AMG since it's the center of the forum. A Weistec 7 ltr 63 would be a creature of absolute pure violence. I think because of the increased stroke torque will really go through the roof. Not sure how the 7 spd will take it though. But seriously does anyone have updates or know a company that does this?
http://www.motortrend.com/roadtests/...e/viewall.html
The 722.6 5spd transmission is one of these strongest if not the strongest transmission AMG has ever built. They can hold massive amounts of torque. Case in point....SL65, SLR, CL65, and E55.
Your talking about the 5.5TT AMG's which uses the MCT transmission, not the old 5 speed.
It's just incredible the amount of torque and power than gearbox handles. It may not be the fastest or most sophisticated unit but it definitely gets the job done. The new MCT is amazing though and it's said to hold alot of power and torque too and it should since the new engines need only a tune to produce mind boggling results. Those new TT V8s are no joke, they will possibly produce the first 9 sec AMG.
I don't know what the rod length is on the M156 but unless a bigger crank is used with a longer rod (achieving a higher piston CH), then the piston speeds and acceleration along with cylinder wall thrust loads are going to INCREASE.
This, of course, means that your engine will be potentially less reliable due to wear on cylinder walls and will have to rev lower (unless you're OK with Formula1-level engine forces on your internals). Drag racing isn't for low-revving cars where I come from.
Again, I'm new so I'd appreciate anyone explaining this.
My thoughts too. With the increased stroke piston speed is reaching F1 levels. 4.20inch stroke would be needed to hit a 427CI.
At 7000+rpm, piston speed is up there.
In all fairness I had a C55 do that is exactly the tranhy I was talking about.
With a 4.2 inch stroke of this modified AMG engine, piston speed would be 5000 at 7200rpm. That is what F1 runs, and I don't think their engines last too long. Given they are operating at higher RPMs constantly.. Its still a lot of strain on the bottom end.
My Harley has a 4.75inch stroke and a 6000rpm redline, piston speed around 4700. I wouldn't push it much higher as the forces on the rods, pistons and crank get excessive.
) even with Weistec kits and torque is what we like
Torque is manly and what separates the ricers from the muscle cars.
Torque is manly and what separates the ricers from the muscle cars.[Weistec supercharged lacking in torque?? Are you for real??
So yes the 6.3s just don't match the 55k for torque. It doesn't mean they're bad engines, I'm just stating facts.
1.85" rod journal rods custom fit ( stock rod is 5.72" long 145.49 mm with a 2.07" rod journal ) https://pauter.com/parts/rods/mercedes-benz/
off set ground stock crank for the 1.85" journal ( stock rod journals are 2.07 ), so you could get approx .20" of additional stroke which would get you to 402 ci ( 6.53L )
custom piston
The smaller rod journals minimize any rod bolt clearance issues in the block and if there were any a die grinder could quickly sort it. I'm confident most of the stroker kits at the time considered a 2.07 or 2.10" rod journal size, which would make the rod bolts more likely to hit than the smaller rod 1.85" rod journal )
