Write-up & Photos :: 18" Forgestar F14 Wheels & Nitto NT05 Tires :: 2010 C63
#51
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Superlubricity,
Great post as usual. You should add your crank pulley to the list of unsprung weight
I am pretty surprised you were able to fit the 18s (even without a lip) to fit over the front brakes. Good to see you were able to do it without a spacer. Long story short, when I put my wheels on with a 5mm spacer, I had a lot of vibration since the spacer covered up too much of the stock hubring.
Re: Weight. The crank pulley is a minus 2-lbs, unfortunately the LSD was a plus 3.5-lbs. You can't win 'em all.
#52
2008 A8L, 2002 996TT X50, 2009 X5
#56
Some quick follow-up notes regarding the tires now that I've had some time in the dry and wet:
- I love how they look. I mean, look at that tread pattern above.
- Straight-line traction is much, much better than the OEM PZero tires. They don't quite hook like my Drag Radials on the street, but that is to be expected.
- As others have commented, they do like a little bit of heat. Once they warm up the traction improves significantly.
- They are very stiff. There is an immediate increase in road "feel" which I consider a good thing, especially when cornering. I have a lot of confidence driving on these tires.
- They are OK in the rain for normal daily driving. No major issues in the city or at high-speeds on the highway in wet conditions. However, I can easily get the tail to kick out through low-speed turns when there is water on the pavement. It caught me off guard the first time it happened as it took very little effort.
- Cold pressure at 38 psi and no loss since initial inflation.
#58
Former Vendor of MBWorld
I tested the NT05's out for Nitto Tires before they were released to the public on my Viper for them at Sebring. I know first hand they are a very good street and light track use tire.
#63
2009 c63, 2011 GT500
#64
A Forgestar vendor on another website reports that the 18" F14s passed JWL testing in June with a load rating of 1,520 lbs: http://www.m3post.com/forums/showthread.php?t=403555
#65
C63 AMG
#66
2013 Chevy 427 Torch Red
#67
Indeed. PM coming at ya.
#69
Trolling the Porsche boards . . . Matt from CampioniShop answered the same question I asked from another member with, "They [the original 18" wheels] tested for higher load ratings, essentially the initial tests did not push the wheels to their safe limits."
#70
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Thanks for the great info. I had purchased 19s but sold em to avoid any fitting issues. Will order 18s for next summer as my track setup but I was really worried about the load rating!
#71
Administrator
On that link from jmf003 the displayed pic in that other thread show a wheel 18 x 8.5 weighing 8.38 kg = 18.4 lbs
Compare the 18 x 12 wheels and you'll see a weight increase of 1.4 lbs: 20 -> 21.4
#72
Just an example. On the forgestar site a link they show this reporrt for an 18 x 8.5 wheel. Link Notice the wheel weight is 17.7 lbs
It's still not 100% clear if they made any changes to the wheel or simply just tested it at a higher rating. I've got a few questions out there.
#73
This just doesn't make any sense.
Why wouldn't the wheel weights be the same? It makes sense that they submitted a new wheel, heavier, to pass a higher load rating, rather than submitting an exact copy of the one that passed at 1200 lbs. Also, the pic of the load rating stamp...is 1200 lbs on the "old" 18" model?
It will be interesting to find out what happened, new wheel or not. Why didn't they test at the higher load rating to start with? Makes no marketing/sales sense whatsoever. Just go read all the complaints on the M boards.
Has anyone tracked these wheels, either in the 63 or an equivalent car? I don't want to be the guinea pig...
#75
Hopefully it works out for you..I do like the wheels, especially the price.
I'm guessing they were marketing to the STi sized car, not expecting that heavier cars like ours would like the 18" wheels as well. They probably assumed we'd get the 19s which are rated at 1500 lbs I believe.
