C63 AMG (W204) 2008 - 2015
Bigger Throttle Bodies, Please Comment
Old Jun 23, 2019 | 12:07 AM
  #276
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Where did you get those blue velocity stacks?
Old Jun 25, 2019 | 05:34 AM
  #277
Celicasaur's Avatar
W212 - E63 AMG
It's a generic turbo v-stack that you can get from ebay. It will take lots of chopping to make it work, but it works well, once you have it nailed down. I've documented the chops that I made on mine somewhere in this thread.
Old Jun 25, 2019 | 08:03 AM
  #278
djjdnap's Avatar
2008 CLS 63 AMG
Originally Posted by skratch77
They are 82mm and what everyone uses. No pin swaps and has vaccum hole like the stock tbs have. 100% direct fit. I just bought a spare for 50 bucks on ebay
This is the tb part number you guys need. Direct fit and confirmed working on my car.
a2731410325
They are from the na 5.5 v8 cars before they went turbo
Wish I would have seen this 2 months ago lol.
seems like the MAP sensor is the problem.
Bought 0261230191 which didn’t say if it fit my car or not but it’s the same plug and fits.
hooked it up and car wouldn’t stay running, unplugged it and it started right up. Plugged it back in and the car ran better than ever. Went for a drive when I restarted it car went straight to limp mode. Cut it off and on and it ran fine but high rpm.
Unplugged the batt over night drove it to work this morning no issues.
Going to try 0261230189, which comes up as the correct part for the car.
08 cls 63 if I never said that.
Old Jun 25, 2019 | 09:40 AM
  #279
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
a2731410325
Right,. if you use the correct throttlebody there is no pin swap.
we sell these throttlebodies for $350, But we also warranty them for 18 months.
Old Jun 25, 2019 | 09:42 AM
  #280
SPONSOR
E55 C63
If someone wanted to provide an STL file we can print Velocity stacks for them.
Old Jun 28, 2019 | 12:22 PM
  #281
skratch77's Avatar
2005 E55
That guy with the insane track c63 is making individual throttle bodies
Old Jun 28, 2019 | 03:56 PM
  #282
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
That build is crazy. He’s actually got it rigged to use only two actual throttle body assemblies to open 8 flaps. Totally mental.
Old Jun 28, 2019 | 04:42 PM
  #283
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
Just sent dude a follow request....ITB's on an M156/9 will be nuts! Wish I had a set too.
Old Jun 28, 2019 | 04:44 PM
  #284
Kriston's Avatar
C63 AMG
wow ITB"s on the C63. but is this truly an ITB setup?
Cant imagine how much "quicker" the throttle response will feel compared to the dual 82's. I mean driving with the Renntech TB's on Comfort mode, has the same throttle response as i had prior to the TB install on sport mode.
Old Jun 28, 2019 | 04:57 PM
  #285
hachiroku's Avatar
SPONSOR
from my personal experiences of ITB's on past vehicles...you gain LOTS of midrange and part throttle power. what throttle response you gain, if tuned will literally let you accelerate with much less throttle % than with a manifold setup due to the additional amounts of airflow without restriction.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jul 19, 2019 | 07:48 AM
  #286
brad65ford's Avatar
2020GLC63
Interesting subject, once everyone agrees on which throttle body is the best direct replacement upgrade someone should create a 3d printed stack for them.
Old Jul 19, 2019 | 02:47 PM
  #287
SPONSOR
E55 C63
IF we get 10 members that will pre order CF/Nylon Velocity stacks i will make them. $170 a pair (Estimate 28hrs per print, That means it will be 2 weeks to print them once the design is done)
Old Jul 19, 2019 | 03:16 PM
  #288
brad65ford's Avatar
2020GLC63
Most likely I'm in just need to know what the whole subject reality is on this throttle body subject, and which way to go. Meaning, it seems everyone is using different throttle bodies also it looks like you have cnc'd an alum lower mount (which looks great btw). But what is ideal setup for basic bolt-on for best performance/driveability and is ECU tuning required?
Old Jul 19, 2019 | 03:35 PM
  #289
skratch77's Avatar
2005 E55
I'm in and have your plate as long as they are like factory and clip into place.
I'm also using mercedes 82mm throttle bodies. No need to do any modifications to mb throttle bodies and never had any single pending codes related to them.
Old Jul 19, 2019 | 10:17 PM
  #290
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
I'd likely be in for a set as long as they'll fit the 85mm setup.....( running E85 and 550cc injectors so suspect I need more )
E
Old Jul 22, 2019 | 06:34 AM
  #291
MBNRG's Avatar
In as well. Have your TB Plate mated to MB 82mm TBs
Old Jul 22, 2019 | 12:43 PM
  #292
SPONSOR
E55 C63
they would be built for 85mm but have backwards compatibility for 82mm
Old Jul 22, 2019 | 01:23 PM
  #293
skratch77's Avatar
2005 E55
Your 85mm tbs are bored out 82s right?
Old Jul 22, 2019 | 01:26 PM
  #294
SPONSOR
E55 C63
and fully rebuilt.
Old Jul 22, 2019 | 08:32 PM
  #295
Texas E63's Avatar
let me know when they're avail with the stacks..... I'm ready.
Old Aug 2, 2019 | 04:39 PM
  #296
skratch77's Avatar
2005 E55
Any update guys? Waiting before taking the manifold off the car again.
Old Aug 2, 2019 | 04:57 PM
  #297
MBNRG's Avatar
+1
Old Aug 30, 2019 | 10:06 AM
  #298
Texas E63's Avatar
anything on this VRP ?
Old Aug 30, 2019 | 10:13 AM
  #299
SPONSOR
E55 C63
Weve finished the CAD drawings, Next we ill print them, And then we will mold them. the 3d material is not suitable for inside the intake manifold.
Plates and throttlebody kits are on sale right now for labor day!
Great time to grab a setup!
https://www.vrpspeed.com/product-cat...amg-m156-6-2l/
Old Sep 2, 2019 | 11:00 PM
  #300
RNS-11Z's Avatar
09 C63
I’ve got a pair of the vrp throttle bodies on the way
have any of you retuned when fitting larger t bodies?
