C63 AMG (W204) 2008 - 2015
Ok, I'm an idiot, but why can't i REprogram my garage door opener
Old Dec 22, 2013 | 11:51 PM
Clark Kent's Avatar
Veteran: Marine Corps
2010 C63
Ya'll drunk and keep parking in front of the neighbors garage waiting to get in. Scoot over one to the left and you'll be okay.
Old Dec 23, 2013 | 12:11 PM
AWD_AMG's Avatar
Scooter
Originally Posted by CoolBDPhenom03
Yes. I've been bugging my HOA about this for years.
Is the keypad locked? My building has the keypad in the open, so I looked up the model number, read the manual on how to program it, and did it myself.
Works like a charm.
Old Jan 12, 2014 | 10:39 AM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by gsrjc
Yes, a lot of people forget steps 2 and 3.
So what does one do when the process of synchronization doesn't work? I just installed a Genie rolling core opener. I clear the old codes on the cars, hold the remote near the mirror, press both buttons, and the amber light flashes slowly forever. It never changes from a slow flash. I had no problem with my old Craftsman (LiftMaster) unit.
I've tried this on both my 2010 ML63 and 2010 C63, and they both exhibit the same behavior. I've tried with the ignition in accessory mode, ignition mode, and with engine running.
What am I missing?
Update:
Was finally able to get both cars programmed. There seems to be no logic to when the car finally accepts the signal from the remote. I just kept trying over-and-over until they rapid flash occurred, and then the rolling code programming portion went off without a hitch.
Way to difficult for something that should be easy.
Thanks,
Joe
Old Mar 31, 2015 | 11:06 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by Valvestud
So what does one do when the process of synchronization doesn't work? I just installed a Genie rolling core opener. I clear the old codes on the cars, hold the remote near the mirror, press both buttons, and the amber light flashes slowly forever.It never changes from a slow flash.
Having the exact same problem now with my new LiftMaster 8500. Had 0 issues programming to my previous opener.
What am I missing?
Update:
Thanks,
Joe
If you hold both the remote and mirror button long enough the slow flash just stops and the light stays off. Did you just keep re-trying this over and over until it goes from slow to rapid flash?
Old Apr 1, 2015 | 12:42 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Looks like one of these are required.
https://secure.homelink.com/homelink...ter-kit-detail
Old Apr 1, 2015 | 05:56 PM
Valvestud's Avatar
Yes, this is what I just added to my garage. You program the repeater to the door control, and the car to transmitter that comes with the repeater.
Old Apr 2, 2015 | 08:49 AM
  #32
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
I thought I wrote this up once before. It's a two step process. You'll need to sync the car to the remote and then sync your car to the garage door opener. These are independent of each other.
Background: the remote is (or should be) already married to the opener itself. You nned to educate your car so it acts like the remote. Once done, then sync the car to the opener.
It is a two step process.
Good luck.
Old Apr 2, 2015 | 08:56 AM
  #33
IRIDIUM's Avatar
V221 / W211 / R231
My experience: put some NEW batteries in your remote.
Old Apr 2, 2015 | 09:25 AM
  #34
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Good luck.
Not sure if you are referring to my post or not. If you are, the 2010 C63 homelink system doesn't sync to the remove because Chamberlin/LiftMaster updated their security protocol to Security+2.0 in 2011 which is not compatible.
If you want to use the homelink buttons in the car, you need a homelink repeater (https://secure.homelink.com/homelink...ter-kit-detail) to act as a communication link in between the car and opener.
I'm sure the homelink system in the C63 got updated at some point. No idea which year though.
Old Apr 2, 2015 | 10:38 AM
  #35
Valvestud's Avatar
Eaxctly! Good post. Thanks.
