K&Ns causing lean condition(ECU mis-fault codes)
During the Service A the dealer proceded to change the K&N filters for a pair of stock filters because the technician read misfault codes stored on ECU. The car runs great and the vibration at iddle is now gone.
The filters were a little bit dirty. Coming from a background of tuning a lot of cars I found in the past that yes indeed a simple air filter can change the AFR dramatically so on my situation I did not want to argue and I am happy to roll back on stock air filters.
Anyone having issues with CEL once in a while using K&Ns? I must admit I am geographically in one of the worst spots in the world(Altitude, poor gas-91oct , extreme heat and moerate dust storms) and I strongly believe smalls things like these can affect the performance.
I believe what you said but I also believe the delaer pink report. Unfortunately I haven't put the car on a dyno to see the AFRs, I have an AEM wideband laying around on my garage and I might actually connect it. Ultimately I was also looking at buying that Ipod software/OBDII scanners that gives you multiple readings like MPG, volts, AFR, etc.
From a customer/owner point of view I must say that I am happy to just run the stock air filters for now, whatever they did(replacing the air filters and /or reflash it) fixed my iddle anoying vibration. Regardless,thanks for your inputs, I am hoping with my recent experience that I can help someone out by providing feedback
