C63 AMG (W204) 2008 - 2015
headlights facing down?
Old Jul 26, 2010 | 11:08 PM
drawde's Avatar
2009 C63
Just me or are the headlights facing a little more down then they should be? How adjustable are the bulbs (i'm assuming that's what is causing this)? Is it something that could have gotten knocked out of place?
I still have a pretty decent view in the dark but I'm feeling like I should be seeing a little further.. I only really notice it on really dark roads at night.
Old Jul 26, 2010 | 11:27 PM
Jae Duk's Avatar
'09 C63
Happened to me once. I don't know if it's possible to fix by adjusting our bulbs because when we turn on the engine you see the bulb adjust itself by moving up then down. I took it to the dealer and they fixed it for me really quick.
Old Jul 26, 2010 | 11:41 PM
Carac's Avatar
2018 E63S Wagon
I believe there's a phillips screw head on the top of the headlight assembly that you can adjust the height.
Old Jul 27, 2010 | 11:00 AM
bluejae's Avatar
'10 C63
i've felt that it pointed low for the longest time. and just thought it was all in my head and that it probably shines a lot more than a car without HIDs
Old Jul 27, 2010 | 02:17 PM
jafores's Avatar
08 C63, 07 ML63, 92 500E, 70 300SEL 6.3, 63 220 SEB Conv. Sold 02 G500, 97 E50,92 C280,71 280SE 4.5
Went through speed pumps really fast once and the headlight reflector was knocked out of its socket ! i though I broke it. i just tried to and succeeded in pulling back in place through the back of the headlight assy
Old Jul 27, 2010 | 04:24 PM
drawde's Avatar
2009 C63
Originally Posted by bluejae
i've felt that it points low for the longest time. and just thought it's in my head. it probably shines a lot more than a car without HIDs
Well as long a its not just me.. Anyone else feel this way?
Old Jul 27, 2010 | 04:45 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Same here. Lights should def come up a bit more. Dark roads I feel the lighting is inadequate..going to check and see if there is adjusters. Than just pull it up to my garage door, and bring the beams up a little bit.
Old Jul 27, 2010 | 05:11 PM
emericr's Avatar
2021 Porsche TTS
As Carac stated there is an adjustement at the top of the light assembly. Just use a large screwdriver and you can adjust down or up to your liking.
Really easy to do
Old Jul 27, 2010 | 09:02 PM
drawde's Avatar
2009 C63
Interesting.. Is it just under the hood or do I need to open the headlight assembly?
Old Jul 27, 2010 | 10:48 PM
Carac's Avatar
2018 E63S Wagon
Just open the hood, it's on top of the assembly.
Old Jul 28, 2010 | 03:40 PM
bluejae's Avatar
'10 C63
can't adjust it too high or it would be illegal right? gotta find the optimum spot
Old Sep 2, 2010 | 11:51 PM
drawde's Avatar
2009 C63
I did this not too long ago.. but then i realized I set them too high.. in my haste to turn them down, i ended up stripping one of the screws.. any ideas how to fix this?
Old Sep 3, 2010 | 12:03 AM
ruthless's Avatar
pontiac firefly
unscrew the screw somehow and put in a new one
Old Oct 23, 2010 | 07:25 PM
drawde's Avatar
2009 C63
Hey guys need some help.. Can anyone tell me what direction I turn the driver side headlight to raise it? As per previous post, its stripped I can turn it now with a bigger screwdriver but I don't wanna waste time turning it the wrong way and not being able to turn it the way I'm supposed to.. Any help would be appreciated
