NOS Octane Booster
NOS Octane Booster
Have anyone used this with C63? Does this really work? Can you feel it?
In one of magazine I read in Japan it said that it made 20hp up just putting this into your car. And makes Octane 4 to 7 point up.
Could this be true?
Could this be true?
C63 Seal Gray
I had a 93 octane tune in my Ford GT and the tuner swore by the NOS Racing Formula, saying by adding a bottle to the crappy CA 91 gas would make it safe for the car to run the 93 tune. BTW, car now has larger Whipple supercharger and makes 715HP at the wheels on straight 91 gas.
On my 997TT w/ high flow cats and EVOMS tune, I put in a bottle of the Racing Formula when I take the car to the track as Porsche's ECU has many maps and would retard the timing once it senses detonation so the higher octane the gasoline has, the less detonation, and thus the high power output.
On my track car, the 2008 Viper ACR, I swapped out the factory ECU to a Mopar Racing ECU which was calibrated for 93 octane but would retard the timing back for CA 91 crapsoline. And so this magic poison helps again. I buy them by the case from Summit Racing.
Give this stuff a try and get the car dyno'd first running the lower grade gasoline, then add a bottle of this stuff, go drive around a while to let the ECU adapt to the new gas, then dyno again, then be sure to report back.
Kinda hard to believe....
Guys thanks I will give it shot and try how it will feel.
I want that energy drink but its not selling in Japan yet. If they do I will drink it for sure.
There was a long *** thread about someone who put a bottle in his motorcycle.
There are many tests done to show octane booster is not the right fix for everyday use as you would spend a ton of money but it does have it's place at a racetrack for limited use.
As "Even Money" mentioned you don't gain power from just raising octane. Higher octane just allows you to utilize all your motors potential if lower octane is causing your motor to pull timing.
Mothballs work also...
In these cars Hiro your tune needs to programmed for the increase in octane or you wont seen any gain. If you have a tune some guys put in a map already for 100 Octane.
I have used and recommend 104 octane boost, black bottle. I used if for track only events running 10 pounds of boost on a mustang. It was used instead of race gas, aka cheaper. With it, I did not have to run any retarded timing, as mine was adjustable from the cockpit
Also, when you run less timing than optimal, your engine will actually run hotter, which was a GREAT concern of mine on track events, road racing only, NOT drag.
Note: If you car does not need higher octane, there are NO GAINS FROM USING IT
I bold ed the last statement because higher octane burns SLOWER, so if you have no detonation, and run higher octane, you actually will LOOSE some HP.
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
I used to mix my own race gas using toluene.
Here is a great read on "boosting" octane -> http://www.w124performance.com/docs/...l/toluene.html
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I used to have a 55 gallon drum in my dads garage. At least until he found out about it
1999 Coupé Fiat 1.8 16v
The only thing where I think about, when I'm thinking of NOS, is the 1st episode of The Fast and the Furious, where the guy gets an enormous boost, and then the car is smoked... not in the good way though...
C63 Seal Gray
Each point translates into .1 and not 1.0. If the octane booster adds 7 points you can raise 91 octane to 91.7 for example.
Your better off just buying 5 or so gallons of race gas and mixing it with the 91 octane. It's more refined then whats coming out of the pump and to be honest I don't trust any additive sold at a store. My favorite is VP Racings Motorsport 109 and it's sold at most performance stores. Plus nothing beats the smell of racing fuel!! Thats like **** for my nose.
My crew chief use to work for Gulf research on octane engines, and DOES know the difference, aka NONE.
Oh well, do what you want to I will still use a little boost at $10 over five gallons at $35 bucks any day of the week.
Are you saying one bottle of NOS will take a tankful of 91 octane to ≈ 94 octane? If so I will buy it by the case...but I don't believe it will even come anywhere near that.
Minus the cost of course. And as was stated above, do not be alarmed when your plugs turn orange. This is normal from the additives in it. Just makes for some hard plug reads. But you could STILL see pre ignition if it was occurring.
Guys, try one bottle. It will be the best $8 you ever spent, and will save you big time.
In a word NO you're not. If money means nothing to you sure go ahead. Your engine does not know or care WHERE the octane comes from. So why spend MORE money on the same effect
My money does mean something to me and to be honest the only time I ever feel the need to increase the octane is when I take my C63 to the track. Otherwise I see absolutely no point in increasing it. If someone can fill me in as to why they would need to increase the octane on a daily basis then I would like to hear the argument. If you drive like a jackass and constantly pushing your engine to higher RPMs, then perhaps getting an extra couple of octane points would be good. Otherwise, if you want to spend MORE and your money means nothing to you, add a $10-$12 of NOS to every tank of gas.
