C63 AMG (W204) 2008 - 2015
Need new rear tires...
Old Sep 16, 2010 | 12:00 AM
  #51
REDSRT's Avatar
2007 SRT8 Charger, 09' C63
Get the Vredesteins, Amazing grip, amazingly cheap. DONT BUY the hankooks, they are garbage in my experience.
Old Sep 16, 2010 | 01:57 AM
  #52
_AMG_'s Avatar
C63
Originally Posted by SonnyakaPig
Would you mind sharing which tires that are made in 265 width actually are wider than 255 P0's?
I would like to get 265's but if it's true that 275's don't rub and if they fit well on the stock rear rims, I may go that route.
One of those tires would be the 265 Dunlop Direzza Star specs. Ive seen them next too a 275 Hoosier tire and they were pretty much the same width.
Old Sep 16, 2010 | 02:00 AM
  #53
_AMG_'s Avatar
C63
Why do you say Hankooks are garbage? I dont think Car and Driver would have rated them number 2 in there best performance tire category if they were garbage.
Please elaborate from your experience.....
Old Sep 16, 2010 | 02:07 AM
  #54
Even Money's Avatar
'15 VW GTI
^ There was a thread, I think, if you search. I've had no problem with 'em.
Old Sep 16, 2010 | 02:58 AM
  #55
SonnyakaPig's Avatar
MB
Thanks, AMG. I'll give those a look.
Old Sep 16, 2010 | 03:16 AM
  #56
_AMG_'s Avatar
C63
No problem.
Old Sep 16, 2010 | 08:48 AM
  #57
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Originally Posted by Questions
Nice.. so I just checked.
There is a 1% speed difference in the fronts going from 235/40 to 245/40
And a 2% speed difference in the rears going from 255/35 to 275/35.
Wheel speed sensor that the car uses for the speedo.. is on the fronts or the rears?
So.... For those who have changed from the OEM sizes to a completely different size, did you account for speed loss or gains, have the speedo recalibrated, etc...
I think I have completely derailed this thread....... sorry..
Last edited by jvanbrecht; Sep 16, 2010 at 08:51 AM. Reason: Messed up the calculations, I need more caffiene
Old Sep 16, 2010 | 09:39 AM
  #58
FBTO's Avatar
2010 C63
Originally Posted by Interwebz
I paid $1120 all in for the set of four RE760, just for comparisons sake.
Do u pics of your setup? I am getting those on saturday
Old Sep 16, 2010 | 10:09 AM
  #59
Mort's Avatar
The speed sensor is usually on the transmission, so I am assuming this is true on the C63 because I don't actually know where it is. Anyway, the driven wheels are the rear wheels on the C63 so they are the ones you use to calculate any speed difference caused by different sized tires.
Determining the exact speed difference may be more problematic due to the methodologies different tire manufacturers use to label their tires compared to the competition and to different tires in their own lineups.
Might try comparing RPM (revolutions per mile) listed on tire rack in the spec for each tire they sell.
or, time a measured mile on the highway driving as close to 60 mph as you can hold it. If the speedo is accurate the time will measure 60 seconds. Any variation from 60 seconds + or - can be used to calculate the speedo error.
Changing the speedo calibration in the tune may be possible but is probably not worth it for a 1% or 2% error. Just make a mental note that you are traveling faster of slower than the speedo is indicating and make a small adjustment to your speed to account for it.
Old Sep 16, 2010 | 02:14 PM
  #60
jvanbrecht's Avatar
After running myself in circles over what tires to get.. I decided to just get 2 rears (265/35ZR18 Continental ExtremeContact DW). Hopefully they will wear out right around the time that the front Pzero's wear out. At which point I will switch to DWS all seasons and pickup a set of cheap rims with tires for track purposes. Since my car is going in for service as well, I did not want to spend too much on 4 wheels to switch to the all seasons for fear of my wifes wrath..... So I went with 2 tires.
Thought about going 275, but it was almost $100 more for 2 tires over the 265, and honestly, I doubt I would notice the difference much.
Old Sep 16, 2010 | 02:43 PM
  #61
propain's Avatar
See Sig
More looks than feel with the 265's to the 275's. I just like how wide the 275's look.
Old Sep 16, 2010 | 03:09 PM
  #62
_AMG_'s Avatar
C63
The 265/35/18 Continentals will be a perfect setup. I wouldn't go with the 275 DW's.
Old Sep 16, 2010 | 03:18 PM
  #63
sflgator's Avatar
'09 C63 AMG
FWIW, I have 265's on the rear and 245's on the front...the sizes I think should've come on the C63 AMG as std.
Old Sep 16, 2010 | 04:15 PM
  #64
Even Money's Avatar
'15 VW GTI
You're gonna track your car on cheap rims???
Old Sep 17, 2010 | 12:57 PM
  #65
jvanbrecht's Avatar
So, I just looked at my tires, closer inspection... They are 235/40 all around. Before I just looked at the tread, that would explain why my traction sucked. After all my comments and questions, you would think I was more observant... Oh well, ordered my tires yesterday, and the are already here... Tirerack shipping is awesome.
