Anyone with kleeman throttle body test data yet??
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Former Vendor of MBWorld
E55,S500,C200 KOMP,SV300 ,LANDCRUISER SAHARA
Ben,
I dont know about the kleeman throttle body,but we have done intense throttle body testing on our premises,this is prety much where it stands,if the manifold where the throttle body mounts is gonna stay the same size as oem,it doesnt matter if the throttle body is 1000mm,it still has to pass thru the "oem" neck which is std size,which makes the whole process pointless and money in the bin.If you want your car to go faster,choose a dyno put you r car on there and see where you stand with power readings,then customise and test from there,this way you can see if your going backwards and forwards,hope this helps
regards sonny
