Put 275's on the rear, and don't like it
2010 C63
I put the re760's on the rear and bumped it up to the 275 width. In a straight line it is great. The extra rubber is awesome. But when I take highspeed ramps at 170 kph, the car feels way less stable. The car seems very bouncy. Not sure if it the size of the tire or the fact that I have pzero in the front and the stones in the rear.
Anyone else experience this?
The problem is that I still have tonnes of meat left on my fronts. I remember taking the same ramp with all pzero and the 255. And it seemed WAY more stable on the cornering. Hmmmmm
The problem is you're running max performance tires on the front, and what are essentially low-end UHP tires with good tread wear on the rears. Just go for some max or extreme performance summer tires for your next set (e.g., Nitto NT05, Bridgestone RE-11). Either way the rear tires won't last that long.
I am running 245/275 star spec right now and have been running this setup for 11k kms already. All I can say is the grip is miles ahead of the stock setup. When i say grip i mean both in a straightline and in the corners.
You might be feeling unstability for couple of reasons.
1) Its getting cold where u live and your tires ain't as sticky as before.
2) Taking mixed tire combo to the limit is a bit sketchy (i mean 170 off the ramp isn't exactly slow)
3) RE760 is not exactly an awesome tire, i mean its not bad but worse than Pzero,starspec,PS2,Nt05,RE11 etc
4) Check your tire pressure
Hope these info helps
2010 C63
Another possible cause is that I have nitrogen in the front and oxygen in the back? I would assume that might have an effect. I am getting the rears filled with nitrogen next week when I take the car to the dealer for squeaky brakes!
2013 Chevy 427 Torch Red
2010 C63, 2002 Corvette Z06
Also - not to be a 'dad' .. but you're a cowboy if you're drivin' 170k on a highway (on/off ramp or not) in this province.. $10k fine, loss of license and road-side seizure... worth it?
WRT your tire situation - running two different compounds is never the best idea. One thing with wider tires that you have to get used to is railroading.. happens all the time and is very unnerving, straight lines or corners. The RE760s really need to heat up as well.. the weather has been cold the past little while and that can have a major effect.
2010 C63
Thanks dad. Actually it is not really a ramp, it is an interchange between the 407 and 410. I have already been on the road for 30 min of highway driving, so they should be warmish.
I will give the brake trick, thanks.
+1... When i bought Yokohamas for the rear of my car and left the ps2 on the front i hated it as well on the highway. I was ready to just have the tires removed and sell them cause i felt like the car's *** was just floating and i didn't have full control. I let out 10 pounds in both tires and have not had a complant since beside the nail yesterday morning.
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Also.. the use of oxygen or nitrogen, this has been hashed out many times.. http://www.straightdope.com/columns/...instead-of-air is a good primer on why not to bother with the expense of nitrogen (unless its free)...
One thing I noticed on bumping my tire in the rear (the previous owner had 235/40/18's on all 4 tires... *sigh* ) to 265/35 is that under hard acceleration, the back end feels a little squirly.. not as stable as the 235's.. might have something to do with the "railroading" reference someone made, but I am not clued up on that.. going to go research it now
I'd say then that what you're feeling is a combination of everything discussed here
a) different compounds front and back
b) tire pressures, etc
c) some railroading
d) just getting used to the different "feel" of the new tires
2010 C63
What pressure are you guys running for the road?
Also my balancing is off. Taking it in tomorrow to get that redone. The tire guys says that happens if the tire didn't set before the enormous torque kicked in.
So I guess I have many things to check out to resolve this issue.
well to be honest I dont know what pressure their set at. When I purchased my wheels I took them to carlsson and they balanced,mounted, and filled the tires for me
other than slow speed and take off grip my stocks felt better around the corners
The floating feeling may be caused by the rear's "hooking up" and causing the front to slightly rise up.
I felt this feeling after I put on the MT’s. Every time I got into the gas the front felt very light almost like it was floating…
2010 C63
Don't think that is it. Cause when I am in the corner, I am at constant speed. No acceleration.
no on a w203 stock set up is
225/45/17
245/40/17
I now run
235/40/18
255/35/18
if anyone is interested in my front tires let me know they are less than a month old with receipts to prove it. Vredestein ultrac sessanta for a hella price.
225/45/17
245/40/17
I now run
235/40/18
255/35/18
2010 C63
I took the car back to the tire guy. He rebalanced the rears, replaced the oxygen with nitro, and reset the tire pressure. It does feel better on the city streets. I will see tomorrow on my interchange corner if it handles any better at the high speed corner. And I think my stock fronts are 235.
