C63 AMG (W204) 2008 - 2015
Dynamat anyone? Thinking of doing it...
Old Oct 13, 2010 | 10:40 PM
HBC350's Avatar
'18 C63A Cabriolet
I love my 09 C63. I don't love the amount of road noise I can hear through the sheet metal of the cabin and trunk. Anyone here ever Dynamat a car? Care to report on your satisfaction with the product?
I saw a Dodge cargo van that was being converted to a luxury liner with the interior completely Dyanamatted. It seemed pretty solid and like it would really provide some significant noise reduction.
Old Oct 13, 2010 | 10:44 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
I dynomat my 09 C350 and it helped qwell the road noise in the trunk. It helped quite a bit. My friend dynomat the roof, trunk and door of his TSX and it made a difference. You must keep in mind that Dynomat isn't exactly lightweight. It'll add more than a few pounds to your trunk, depending on how much you're planning on adding.
Old Oct 13, 2010 | 10:46 PM
HBC350's Avatar
'18 C63A Cabriolet
I'd add 25 lbs to my trunk if it would make the car quieter!
Old Oct 13, 2010 | 11:00 PM
I am Jeff's Avatar
Then you should definitely get the dynomats!
Old Oct 14, 2010 | 09:39 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Lose 25 pounds of weight and its a wash
Old Oct 14, 2010 | 12:20 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
If you're going to dampen sound and reduce vibration, I'd highly recommend Second Skin (www.secondskinaudio.com) Damplifier Pro instead of Dynamat. I've tons of research and some testing and this Damplifier easily outperforms Dynamat and even Dynamat Extreme. Much better engineered (even overengineered) product. I did the whole trunk and wheel well and made a huge difference. I also added a second layer of Luxury Liner Pro to further block outside road noise, which helped with audio quality.
Here's a thread with some pics of 204 with the sound dampening.
https://mbworld.org/forums/c-class-w...d-you-use.html
It can be a DIY project, but will take the better part of a day to do. Nitrile or latex gloves help as you'll probably cut up your fingers handling the foil.
Old Oct 14, 2010 | 12:24 PM
_AMG_'s Avatar
C63
I ave used dynamat in my Escalade, it works great. If you want to get rid of any rattling noises, dyanamat is the way to go.
