AMG door pins - Ebay alternative.
BTW-My PDR hot glue solution is working very well on the rear pins. The "AMG" on one of the rear is not aligned @ 100% perfection and I cannot turn them and when I push the pin down and pull it up, it is still on very tight.
So for those who have done this, how hard do you have to pull?
And for the fronts do they screw off or do you turn and pop them off?
Thanks guys!
I put my fronts on with a little piece of tape as well as I didn't want to screw them all the way down and one went on further than the other. They seem secure for now and I don't think they will turn when operated. I was able to install them so they are even side to side.
I faced mine to read from the inside. I have tints and you can't read them from outside unless the window(s) are down.
PayPal = meadowsm@gmail.com
He got 3/4 on just right with no tape or glue. The passenger, rear door pin gave us some trouble. So we're going to get it right tomorrow.
I really like the way the new AMG pins look.
I just thought I would mention this because perhaps the rear pins are meant to have a touch of glue inside of them.
https://mbworld.org/forums/c-class-w...-pictures.html
I read through that thread and it seems like the installation process is far more involved than I will be able to do, even with the help of a MB mechanic.
But, it does help to know that to pull the door panel off, you unscrew the torx bolts (we all know that) and then pull from the arm rest and the panel is supposed to pop off. I didn't know that and I hope it helps tomorrow.
And yes, this mod is totally useless to some but for me, it's been a godsend considering I have to use a parking access card three or four times a day. These pins will save me a lot of pain in the future!
i noticed it again yesterday when i went to a drive up atm machine... it just made things a heck of a lot more comfortable...
The only pin that gave us some initial trouble was the passenger, rear door pin. But, we got that on today.
The heights of the pins when the door is locked/unlocked is pretty even, so I'm happy.
Overall, I really like the look. And I'm grateful TS pointed us in this direction.
