C63 AMG (W204) 2008 - 2015
Update from AMG Pro/GT3 testing event
Old Nov 23, 2010 | 12:48 PM
harrower's Avatar
2009 C63, 2007 GL 450
Guys,
Pressed for time but thought I would do quick post of some new products displayed at AMG Pro/GT3 Team testing over last 2 days in Paul Ricard.
CF drivetrain and racing brakes. I will do full report post later on.
Dave
Attached Thumbnails Update from AMG Pro/GT3 testing event-gt3-new-products-001.jpg   Update from AMG Pro/GT3 testing event-gt3-new-products-002.jpg   Update from AMG Pro/GT3 testing event-gt3-new-products-003.jpg   Update from AMG Pro/GT3 testing event-gt3-new-products-004.jpg   Update from AMG Pro/GT3 testing event-gt3-new-products-005.jpg
Update from AMG Pro/GT3 testing event-gt3-new-products-006.jpg
Old Nov 23, 2010 | 12:51 PM
JamE55's Avatar
Out Of Control!
Sweet!!
The Brembo GT brakes and CF driveshaft looks yummy!
Old Nov 23, 2010 | 01:41 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
What is that CF driveshaft for?; the SLS GT3 race car?? That thing is bad a$$
Old Nov 23, 2010 | 02:01 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
I thought the standard SLS uses a c/f drive shaft back to the rear transaxle already?
Old Nov 23, 2010 | 06:38 PM
harrower's Avatar
The driveshaft is off the GT3 and weighs in at 7kg or so.
Old Nov 23, 2010 | 06:40 PM
harrower's Avatar
That I have no idea about. These were the products that were on display with the GT3 so I assumed they were designated for GT3 only but I could be wrong.
Old Nov 23, 2010 | 06:48 PM
LZH's Avatar
LZH
I assume you are referring to the SLS GT3, correct?
Old Nov 23, 2010 | 06:52 PM
harrower's Avatar
That is correct
Old Nov 23, 2010 | 08:16 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
thanks for posting!
Old Nov 23, 2010 | 09:58 PM
hhughes1's Avatar
FYI: probably not the same as the one on display but cool none the less.
AMG has seen fit to design a new seven-speed transaxle gearbox for the SLS. Mounted at the rear axle and encompassing the differential, the new gearbox is a dual-clutch automated manual transmission that will shift gears by itself or at the driver’s command. This is unlike the MCT unit in the SL63 AMG, which is a variation of Merc’s seven-speed automatic that uses a planetary gearset and a clutch pack instead of a fluid torque converter. Connecting the engine to the rear-mounted transaxle is a torque tube housing a lightweight carbon-fiber composite driveshaft
