C63 AMG (W204) 2008 - 2015
mobil 1 0w40 for c63 amg ? is it ok ?
Old Sep 12, 2018 | 01:22 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
his girlfriend must love him...he brings up the past.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Sep 15, 2018 | 01:47 PM
shaun.barnard's Avatar
2012 C63 AMG Coupe
After countless oil research on this forum and others and dealers, use 0w40 if you live in the snow. Use 5w40 if you live in warm conditions otherwise you are going to get premature cam, lifter and cam adjuster wear. I live on the coast of South Africa and 13 degrees Celsius is the coldest we get on average so adjust your oil to your climate. There's no one oil that fits all AMG's. I use Liqui Moly 5w40 or Petronas 5W40. AMG specked 0w40 in the beginning then they found out they made an F,up and changed it to 5w40 here. Speaking from experience so you can take my word for it.
Old Jan 10, 2019 | 06:11 PM
zonnie's Avatar
2011 C63 AMG
What if I live in Vancouver, Canada. 0w40 or 5w40?
https://www.theweathernetwork.com/ca...mbia/vancouver
Old Jan 11, 2019 | 04:56 AM
Cohen63's Avatar
2012 C63 AMG P31
You should go 0w40 because you live in a colder climate. The 0w40 oil is thinner than the 5w40 oil when cold, and will therefore be able to get into the top of the engine quicker upon cold start for better lubrication.
Old Jan 11, 2019 | 07:53 AM
2012 C63 AMG Coupe
+1
Old Oct 10, 2019 | 06:26 PM
yeswife's Avatar
C63 Coupe 507 Ed
+1
thanks to this thread.
I see you guys have selected Motul 5w40 for warmer climates.
I will pick the same here in Australia as we are going into summer.
it’s Mobil 1 or Motul for me.
thanks.
Old Oct 10, 2019 | 09:04 PM
  #32
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
I'm also in Sydney and recently replaced all my tappets due to ticking and put in liqui moly 5w40 leichtlauf high tech with Ceratec and engine is now purring.
Bought the liqui moly 5w40 leichtlauf high tech and Ceratec from Spares Box thru ebay (better price than Spares box direct).
Old Sep 10, 2020 | 06:57 AM
  #33
Ninjadom's Avatar
C63 2011, 125 Edition
I’m in England. Just got Mobil 1 0w-40 from Opie Oils. 5 litres for £46 including delivery.
Old Oct 5, 2020 | 12:24 PM
  #34
Bay Leaf's Avatar
SL 350 R231
I recently changed the oil and filter (using a Mann filter ) but I've since found out that the oil was 229.3 instead of 229.5 will this be of any detriment to engine and should I drain it out and put in 229.5
Old Oct 5, 2020 | 12:59 PM
  #35
blurred's Avatar
2013 C63 P31
You're in the wrong forum, this is c63 and quite a different engine requirement.
Old Oct 6, 2020 | 06:05 AM
  #36
Bay Leaf's Avatar
SL 350 R231
I'm aware that this is not the correct forum as such but the oil specification is the same for my engine which is the M276 3.498 cc
Old Oct 6, 2020 | 07:14 AM
  #37
blurred's Avatar
2013 C63 P31
well then what oil did you use?
Old Oct 6, 2020 | 07:44 AM
  #38
Bay Leaf's Avatar
SL 350 R231
If you read. my original post you will see I used 229.3
Old Oct 6, 2020 | 08:04 AM
  #39
blurred's Avatar
2013 C63 P31
there are many oils in that spec. For instance there are also many oils in the 229.5 spec for an m156 but we are only allowed to use a few of them. So if you used a 5w30 but you are only allowed a 40wt then it matters more than if you are allowed a 30wt. Thats why you'll get a better answer on a forum for your engine/car, where owners have already researched what the spec entails.
Old Jan 22, 2024 | 07:16 AM
  #40
xaibqazi's Avatar
c63 2017
C63 w205 2017 from dubai getting original mb oil from outside
Originally Posted by nasser
thanx very much guys ..
mercedes-benz in dubai uses shell helix ultra extra 5w30 and he said that its better than
mobil 1 is it right ??
great to see someone from dubai too
