C63 AMG (W204) 2008 - 2015
cargraphic headers installation
Old Dec 1, 2010 | 07:12 AM
cayenne_ksa's Avatar
c63s
Hi everyone,
I'll be installing cargraphic headers on C63 which belongs to friend of mine. We decide to do the work together. I do have lifter and tools but I was wondering if there is someing i need watch for. if anyone can help with comments or links for DYI's or installation manual i would highly appreciate it.
thanks in advance
Abdullah
Old Dec 1, 2010 | 08:20 AM
RNS-11Z's Avatar
09 C63
from the installation of mine, they easy to fit, but it would be wise if you use a hoist. Apparently getting in from underneath makes life very easy.
h.
Old Dec 1, 2010 | 11:23 AM
Sincity's Avatar
I read on MHP headers, you will need to disconnect the steerring shaft that goes to the rack. Ask Mthis, he and his friend installed theirs using jack stands.
Old Dec 1, 2010 | 02:39 PM
c63s
it took me almost 4 hours to get the headers on the passenger side out. It's really tight and I pearly could move my hands. Now the bottom screws for the driver side is out but the top ones still. It is pain in A$$ to get them out and I don't know how I will be able to do them tomorrow. anyone gone through same experience ? any tips ?
Old Dec 1, 2010 | 02:41 PM
c63s
h.
It was not easy at all. removing the cat was piece of cake, but the headers are big time consumer. what tools did you use to get access to the screws ?
Old Dec 1, 2010 | 03:57 PM
Sincity's Avatar
Have you tried accessing the upper nuts by removing the airboxes?
Old Dec 1, 2010 | 04:06 PM
c63s
I did but still. It's too tight. i will take pix tomorrow and post it
Old Dec 1, 2010 | 05:03 PM
mthis's Avatar
Anything W/4Wheels
1st 3 top screws should come out from top. The last top screw towards the driver should comeout from under the car.
Old Dec 2, 2010 | 02:03 AM
c63s
anything need to be disassembled rather than the air filter?
Old Dec 2, 2010 | 06:49 AM
AlexCim's Avatar
2011 Ultima GTR
I was about to post the exact same topic as I'm gonna probably give it a go myself too.
Cayenne_ksa - Please post any tips/tricks you work out along the way, I'd love to be able to finish this in a day's work.
Old Dec 2, 2010 | 07:15 AM
RNS-11Z's Avatar
09 C63
Alex, we fitted my whole exhaust in about 4 hours, but to do removal of stock and ment of new i wouldsay should take the whole day because u have to wire up rear flaps. I would recommend getting a work shop to do it
where r u located in aus?
Old Dec 2, 2010 | 07:18 AM
AlexCim's Avatar
2011 Ultima GTR
Im in Melbourne.
I know I can get a workshop to do it, but honestly, I just want to do it myself. I miss messing with cars :P, it's half the fun.
I have a friend who runs a car audio shop anyway, so he can help with the wiring and also has a hoist and like.. seriously... EVERY tool from the Snap-On catalog
Old Dec 2, 2010 | 11:40 AM
c63s
can you give you me more calirfication regarding the wiring. I'm almost don't and would like to make sure all done right
abdullah
Old Dec 2, 2010 | 11:41 AM
c63s
and yeah it took me decades to unscrew and screw the headers. I don't know if it's the tools or our hands but it's so tight and I can pearly move my hands.
Old Dec 2, 2010 | 11:58 AM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
Installing a 63 header
Here are some tips:
To make the install as easy as possible, start by removing he airbox. the disconnect and removing the coil packs and pug wires as one unit. You are going to need all the room you can get. Under the car disconnect the steering shaft from the car. TIP: make sure your steering wheel in side the car is dead strait; do not move the steering wheel when the shaft is off or you could risk messing up your steering angle sensor.
once you have the stock manifolds removed you can start installing the headers. However after removing the stock manifolds, you may run into a manifold/header stud that did not come loose instead the whole stud backed out nut included. Dont worry you can just put it back in.
Pending on the design of the header flange being about to get to the bottom studs/nuts can be very tricky. You may want to think about removing a heat shield to help with room to work. Some times you wish your fingers had eyes when installing a 63 header.
Old Dec 2, 2010 | 12:26 PM
c63s
wow thanks for the great info MBH and I highly appreciate your support. I didn't miss with the coils but I did removed the air filter and disconnect the steering shaft but didn't know about the steering sensor. Fortunately I didn't touch the steering and it was left straight before work stablished.
as of now everything is almost done and I'm uploading some pix
here is what I would like to make sure about.
factory system has the sensor before and after the cats. In the cargraphic system it's a bit different. Do you I need to do anything about the wires ?
Also the point where all pipes join in one pipe, do i need to do any kind of sealing ?
Old Dec 2, 2010 | 12:33 PM
c63s
here is more pix
http://www.flickr.com/photos/by_desi...7625514653166/
AGAIN I HIGHLY APPRECIATE MBH HELP AND ALL THE OTHERS MEMBERS
ABDULLAH
Old Dec 2, 2010 | 02:42 PM
Sincity's Avatar
Originally Posted by cayenne_ksa
wow thanks for the great info MHP and I highly appreciate your support.
Did you mean MBH?
Edit: Even I got it wrong.
Old Dec 2, 2010 | 04:40 PM
c63s
Did you mean MHB?
yes sorry typo. thanks for correction
Old Dec 2, 2010 | 04:50 PM
AlexCim's Avatar
2011 Ultima GTR
The heat shield must stay right?
Has anyone wrapped their headers in that cloth tape?
Feedback about said cloth tape?
Old Dec 2, 2010 | 04:57 PM
Sincity's Avatar
They should be on now. How do they sound with the CAT? Video please.
Old Dec 2, 2010 | 05:38 PM
c63s
I love it
http://www.youtube.com/watch?v=oVjGDzDx_bU
Old Dec 2, 2010 | 06:33 PM
Did you mean MBH?
All the reason my I need to change my name lol
Old Dec 2, 2010 | 07:09 PM
RNS-11Z's Avatar
09 C63
Hpc coat it instead
Old Dec 2, 2010 | 11:00 PM
AlexCim's Avatar
2011 Ultima GTR
Hpc coat it instead
Did you ditch the heat shield?
