C63 AMG (W204) 2008 - 2015
Photos :: 18" Forgestar F14 Wheels, Michelin PS2 Tires and H&R Springs :: 2010 C63
Old Jan 10, 2011 | 10:48 PM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Originally Posted by RStevens63
Whatever works!
Ha, wasn't being literal. I just threw a lot of car parts on the scale that day; evident by the data in that thread.
Old Jan 10, 2011 | 11:27 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
Originally Posted by EUGENE-Taiwan
I would have gone 19's
And OP- Your car looks so sick! That CF hood and those wheels and tires, your a lucky man.
Old Jan 11, 2011 | 02:38 AM
Cyan 740i's Avatar
SL55 Widebody
love the look. great job.
Old Jan 12, 2011 | 02:51 AM
thank you!
Old Jan 12, 2011 | 02:56 AM
PistolWhipC63's Avatar
C63 AMG
Perfect size and setup.
Old Jan 12, 2011 | 02:52 PM
_AMG_'s Avatar
C63
Hey Super, is there a big difference in ride quality and handling after putting in the H&R's?
Old Jan 12, 2011 | 05:02 PM
  #32
Matt_Eurojerks's Avatar
w204 C300
Those WILL be my next set of wheels. I have confirmed it today! Great stance, great offsets, great size.
Old Jan 12, 2011 | 05:31 PM
  #33
Originally Posted by superlubricity
thank you!
How does your car feel on 18's? Is it more smooth than it was with the stock 19's?
Old Jan 12, 2011 | 09:43 PM
  #34
blindfold's Avatar
C63
gunmetal looked sweet and silver wheels looks classy, well done
Old Jan 13, 2011 | 07:34 PM
  #35
Mort's Avatar
I believe superlubricity's stock wheels are 18".
Old Jan 13, 2011 | 09:23 PM
  #36
Then disregard.
Old Jan 15, 2011 | 12:55 AM
  #37
I haven't had much seat time with this combo to really comment on the handling or performance.
It's been either raining or snowing the past two-weeks.
Once the weather clears up I'll put these wheels, tires and springs through some spirited testing.
Old Jan 15, 2011 | 09:43 AM
  #38
blindfold's Avatar
C63
is it possible or necessary to fit 285s or even 295s on a 9.5" wide wheel? thanks
Old Jan 15, 2011 | 11:15 AM
  #39
Kreuzfeuer's Avatar
SRT-6
I'm running 285 on a 9" wide wheel... no issues at all
Old Jan 15, 2011 | 04:19 PM
  #40
You can fit both of those on a 9.5" wheel but whether it will fit on the rear of a C63 is a different story. It all boils down to three things; offset, actual tire width and the suspension height.
Old Jan 15, 2011 | 05:18 PM
  #41
hhughes1's Avatar
2013 Chevy 427 Torch Red
To be clear nearly every tire manufacturer lists 275 as the maximum tire width for a 9" inch wheel. What actually works and whether you are comfortable going outside of recomendations is personal choice.
Old Jan 23, 2011 | 08:22 PM
  #42
Forgot to post this photo of the Spring Pads.
On the Left, Pad #4 (Part # A 210 325 04 84) - 17mm
On the Right, Pad #3 (Part # A 210 325 03 84) - 13mm <- This one is standard on the C63
Old Jan 24, 2011 | 08:48 PM
  #43
South Ocean1's Avatar
2020 Porsche Taycan Turbo, 2020 GLC 63, 2014 Audi S6, 2014 GL63; past 2019 M5 and 2011 E63
Superlubricity:
I wanted to circle back with you to thank you for your input on your experience with the Forgestars. I finally have my set on and am pleased with how they feel and look. Thanks again. In case you are curious to see what they look like on a W212 E63, here's the link:
https://mbworld.org/forums/w212-amg/...ml#post4479103
Obviously I am biased given that I have chosen similar wheels, but I like the look of your car better with the brushed titanium F14s than with gunmetal F14s. I think they really provide a nice "pop" next to the steel gray color of your car.
Kind regards
Old Jan 24, 2011 | 11:51 PM
  #44
Kreuzfeuer's Avatar
SRT-6
I'm with you, I was concerned it would be too wide.
Several folks on the Crossfire boards were running that size, and had great results so I figured I'd roll the dice. So far, I've been very happy. Ride is solid, and reassuring enough that I've tackled the Tail of the Dragon a few times, as well as numerous 150mph runs with zero problems or unsettled feel. Traction is much improved all around.
Pics:
Old Mar 8, 2011 | 12:50 AM
  #45
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
super, where can I buy the spring pads #4? Thanks for your good post!
Old Mar 8, 2011 | 01:27 AM
  #46
They are OEM parts.
Your can buy from your local dealer or online dealers like getmercedesparts.com
Old Mar 8, 2011 | 08:22 AM
  #47
Roswell's Avatar
Thanks a lot super... but online it says it's for the W210? Is it the same part for our cars?
Old Mar 9, 2011 | 12:54 AM
  #48
Both of the part numbers above will work on our car.
The #4 pad comes standard on other models but works on the C63 to increase height in the rear by 4mm compared to stock. You need one on each side.
Combine these pads with the H&R springs and you get a nice even drop front to back.
Old Mar 9, 2011 | 05:13 PM
  #49
kart125's Avatar
2008 Saab 93 TurboX SC (BSR stage 1)/2014 E63 S Wagon (Rebellion Tuned/Renntech Sport Mufflers)
I really like the look of both your setup but I have a little more love for the gunmetal set but that's personnal!
Quick question... I'm not a big tech guy when it comes to aftermarket wheels (offset and everything). I was considering adding some wheel spacers to improve the look of the stock 19 inch wheels I have.
How many mm should I go to get the look you have? I was thinking 15mm front and rear (H&R spacers). What do you think?
Old Mar 9, 2011 | 05:23 PM
  #50
GHAZAN's Avatar
MBUSA
stock 19s are:
19 x 8, 46
19 x 9, 55
I would run 10mm front and back for a nice balance not too aggressive and still relatively safe. You'll need longer lugs. Stock 14 x 1.5 x 27-28
