E63 with Forgestar F14s for Winter
Please note that the stock offsets with 18s on the rear wheels do NOT work, as the curve of the rear wheel does not leave enough space for the rear brake calipers - thus the need for the more aggressive offset on the rears. I found that out the hard way.
A very special thanks to WheelSTO (Northbrook, IL) for identifying the clearance issue on the original set and working with Forgestar to get the correct fit for the rear wheels and to Forgestar for making it happen. In my view that was great service by both WheelSTO and Foregstar. You don't find that enough (great service) these days and wanted to commend it when I did find it.
Blizzaks are hands down, the best snow tires you can buy, short of studded tires, IMO.
Mockbam 5, I have always had good luck with the Blizzaks. Going back to my former E55 also with the Blizzaks, I have never had a problem getting around in the snow and never (knock on wood) have gotten stuck. The only challenge with the E63 is that it has so much more power than the E55 (2001 version) that you have to be extra careful not to break the rear tires loose when driving in snow - even in comfort mode with traction control on. Also, the Blizzaks handle reasonably well at lower speeds on dry roads and only start to feel "floaty" relative to the performance tires at highway speeds around 65 or up.
Yes - all went well with the Blizzaks this winter. I had the biggest test of all when I drove into Chicago the afternoon after our monster blizzard of early February and made it in (and back) just fine (albeit slowly). The only issue I found on that day was ground clearance - with 14 inches on the ground I had to wait until the plows had done at least one pass on the streets before I would venture out. One other note, I found the MCT transmission in comfort mode allows for really easy throttle modulation when starting out in the snow - which helps a lot.
Hopefully that info is helpful.
This is the best car I have ever owned so I would support your decision to move to an E63 as a daily driver in Chicagoland. Good luck!
