Performed Service B myself, few pictures and questions
Maybe I will just use the warranty coverage money for an extended tune and headers and hope I don't break anything too expensive or that I cannot replace myself.
How do you reset the maintenance minder? I tried to follow the direction online but mine gives a warning saying it can't reset unless I go to the dealer.
2007 E63 w/P30 and Eurotech CF Diffuser
The reason I drain
Dear,
Thank you very much for your post.
The drain plug at the front of your E 63 AMG engine is not convenient for draining the oil. Following the service instructions on the E 63 AMG, only the drain plug in the oil pan at the back of the engine is appropriate for draining the oil. Extracting through the dip stick is not possible either. A nearly complete emptying is guaranteed while your engine is at operating state temperature. A possible remaining quantity in the front area is negligible.
We hope this information finds you helpful.
Best regards,
AMG Private Lounge Team
Best regards,
I change the cooler when I change the oil. I was thinking about extending the warranty so finding out about this kind of sucks.
I figured I have all the gremlins worked out now... There is tons of witten off C63's on the net to get used parts too.
