DIY Black Emblems
2009 C63
DIY Black Emblems
This may have been discussed previously, but I decided to black out my rear emblems with the use of some Plasti Dip purchased from Lowes. I first cleaned the emblems with alcohol then applied three coats over about 10 minutes and then let dry for an hour. The excess peals off. The emblems can also be returned to chrome by pealing off the Plasti Dip. Total cost about $10.
![](http://jch.smugmug.com/Cars/C63/DSCN1537edited-1/1215303801_9uVKG-L.jpg)
![](http://jch.smugmug.com/Cars/C63/DSCN1539/1215304261_3yRrK-L.jpg)
![](http://jch.smugmug.com/Cars/C63/DSCN1545/1215304942_tXVWa-L.jpg)
![](http://jch.smugmug.com/Cars/C63/DSCN1542edited-1/1215307467_oWFzu-L.jpg)
Man that looks great! I think I just may have to try this...but I do have one question; how were you able to peel off the excess without pulling anything off the emblems themselves? In particular, how did you peel the excess from the inside of the star and around/in between the letters/numbers?
Thanks!
Thanks!
2009 C63
Thanks!
Thanks!
Here's a link to a Lexus thread that does a good job of explaining
the process:
http://www.clublexus.com/forums/is-s...-required.html
14 GL550; 14 E63s
Plasti-dip is some amazing stuff. I tried to black out my side markers using PD, but I could not get it to go on evenly. i kept getting little air bubbles trapped.
I thought about even using it for my rear spoiler, but after the issues I had spraying it on I decided that was not a good idea until I figured out how to use it.
Any suggestions?
Any suggestions?
2009 c63
Thanks!
Thanks!
props to OP to getting it done right the first time!
2009 C63
Having just applied it I don't have any experience with it yet, but the Lexus thread states that it holds up well over at least a couple years to rock chips, washes, etc. Probably want to keep wax off of it though so it doesn't discolor. You can always peal it off and reapply if necessary.
Nice DIY I did same thing last weekend, but I took the emblems by accident yesterday I wish I didn't.The front grill should get this done to protect it from rock chip.
But guys make sure to apply more that two clear coats using the PD to get thick rubber coat and can easily remove it.
'15 E63S wagon
This is a VERY cool trick, thanks for sharing! I'd be nervous spraying my paint w/plasti-dip spray but obviously it pulls off the paint. Not so sure about doing wheels like this (Lexus guys) but the emblems would be easy enough to touch-up if they got scuffed.
2010 Irridium Silver MB C63 AMG Sedan
Exactly what I am going to do with my front grill and I am going to use the the same technique. I dont think with plasti dip you need to remove parts because excess just peels off...
Looks good!
Looks good!
Thanks!
C63, Grigio Medio E46 M3
Heres my Plasti-Dipped grille.
![](https://i902.photobucket.com/albums/ac228/Wbucco79/11683d1f.jpg)
Heres the removal..
Remove the two plastic push fasteners on the top of the grille, than push the grille at the bottom where it meets the bumper. This will unclip it from the bumper. Now lift the grille straight up..
__________________
Heres the removal..
__________________
'15 E63S wagon
For the emblems, the plasti-dip makes sense b/c you can't easily remove them w/out having to realign and resecure them.
For the grille though, wouldn't it make more sense to remove the entire part and spray w/something more durable? Like a flat/matte enamel spray.
03 CL500 amg package/08 Audi S6/07 Range Rover Sport/06 cls55/09 c63
great job. and seems very simple - i was thinking about blacking out my cls55 grille or buy buy another one and have it painted but this seems to be able to do the trick!
