C63 AMG (W204) 2008 - 2015
Oil temp fluxuating
Old May 3, 2011 | 01:33 PM
PistolWhipC63's Avatar
C63 AMG
Oil temp fluxuating
I've noticed the normal temp usually for the oil is around 215F, but lately it goes to 215 and under some mild/hard acceleration flicker to around 201F. I mean the temp just jumps around from 215 to 201 then back to 212 then back to 205 and so on and so forth.
Please help. I've checked the oil and it seemed it was barely over the minimum so i added about a half a quart and it was around the middle. My car is at 7900 miles. Does the car run cooler when you rack on more miles? Thanks in advanced
-Steve
Old May 3, 2011 | 01:45 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I have 8800 miles on mine, and it always run at 215 in warm weather. When the weather was much colder it ran in the neighborhood of 198-203, depending on the outside temperature. It might just be the temperature sensor, is going bad. I would have it checked out, since it's under warranty.
Old May 3, 2011 | 02:11 PM
CELLryuu's Avatar
C63 AMG Coupe P31
mine runs at about 215-220 also in normal driving but when im racing around on the highway it gets way up to 250!!!! that kind of bothers me. anyone know if thats bad for the engine....i know its not good but should i be worried?
Old May 3, 2011 | 02:19 PM
vmx128's Avatar
2011 C63 P31
Mine goes up to 235-241 on hard acceleration, and when it does, I can hear a loud fan noise from the engine bay. Almost sounds like a (quiet) vacuum cleaner!
Old May 3, 2011 | 02:21 PM
vmx128's Avatar
2011 C63 P31
Sounds normal. If I can hit 240+ in 70-80 degree SoCal weather, I can see it going up to 250 on a hot Dallas day!
Old May 3, 2011 | 03:01 PM
C6G's Avatar
C6G
C63
Sounds about average mine hovers around 210 driving around town in C mode. It also fluctuates 5 to 10*f. When I start driving more spirited it will jump up to 220-225. Damn 250! I don't think mine has ever seen that, even after back to back passes on the track. Guess Im lucky my climate is a bit cooler here up north.
Old May 3, 2011 | 03:34 PM
bluejae's Avatar
'10 C63
... i've never seen my temps go near 240-250... i can't even recall it ever being in the 230s... when driven hard, for a few seconds to minutes... it's in the 220s
Old May 3, 2011 | 03:45 PM
C63 AMG
The thing is my temps have been dropping and rising. When i drive it hard it will occasionally get to around 220's, but lately it's been dropping to low 200's then back up to the normal 215.
Old May 3, 2011 | 03:59 PM
black-clk500's Avatar
'14 911S (garage queen) '13 X3 (family hauler)
mine usually runs at 212F once fully up to temp and cruising speed.
Spirited driving bumps mine into the high 220s, but I can't recall seeing anything in the 230s, but I'll have to check this summer.
I got my car last Fall and just started to drive it again recently and the temps outside haven't been above 80F since I got the car.
Old May 3, 2011 | 04:11 PM
vmx128's Avatar
2011 C63 P31
I just picked up my car from the dealership after Service A. On the way back on the highway, the oil temperature was hovering around 220. It is a particularly hot day here today. The outside temperature was reading 97 degrees!! As soon as I got of the highway and stepped on it a couple of times, the oil temp went up to 231.
Old May 3, 2011 | 04:19 PM
JeffDL's Avatar
C63
never check mine damn 09 not letting me display songs on command screen.
Old May 3, 2011 | 04:22 PM
vmx128's Avatar
2011 C63 P31
haha. how did we go from oil temperature to songs on comand screen.
Old May 3, 2011 | 05:12 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Ok, I just got back from a good romp to the office and back. the most it got up to on the highway this time was 223 but cooled back down to 219 after i started cruzing.
On the back roads to the office it got up to 230 and its not even that hot out today
Old May 3, 2011 | 06:26 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
My average in Houston weather is 215 to 225. Only time it went above 225 was after my first oil change at 1100 miles. After hitting 235 it went back to normal. Gave me a scare. Parked the car to make sure oil cap wasn't loose or missing.
Old May 3, 2011 | 07:31 PM
C63 AMG
I just went out for a drive and went to start the car and heard clicking in the engine. So I revved the engine slightly and the clicking seemed to match the rpm's. I'm starting to think i have a bad purge valve. I'll prob just take it in to the dealer even though i hate them touching my car.
Old May 4, 2011 | 12:54 AM
Djovovic63's Avatar
Mercedes C63 amg, Bmw X5,
I dont know how hard you race your car but mine also usually runs around 215-220 and when I drive it little bit more spirited it will get up to 237. But I did get it up to 250 when I was really driving it hard.
If I am not mistaken at AMG academy the amg's constantly heat up to 255-260. Thats what I heard.
Old May 4, 2011 | 03:42 AM
Exacc's Avatar
E46 M3, '09 C63
Took mine to the track, went up to 264...no biggie. I think it all depends on your oil rating, and at what temp it can still protect the engine. I think for Mobile 1, no worries till close to 300.
Don't worry about it, it your fluxuating capacitor makes you travel through time...JK
Old May 4, 2011 | 09:16 AM
ATL_MB's Avatar
2010 C63
Mine's hit 275 after several hot laps on a beautiful (HA!) Georgia summer day. That was with the A/C off and heater running full blast.
Old May 4, 2011 | 11:18 AM
bushburninc63's Avatar
2009 c63, 2010 E63
highest i've seen mines goes up to is 230. Normally it runs 220 and under. That reminds me I need to top off my oil.
Old May 4, 2011 | 11:37 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I had mine up to 260 on a 100+ day at Summit point race track... I changed the oil the next day though heh..
Old May 4, 2011 | 04:07 PM
_AMG_'s Avatar
C63
Mine usually reads between 212-217. Hard driving reads around 228-230.
Highest it went was 240+
Old May 4, 2011 | 04:19 PM
C63 AMG
I recently read a thread where boris was having problems with engine tick and it turned out to be a lifter. Do you guys think it could be the lifters not working properly and giving me a misread on oil temp...? It's wierd when my oil temp is at 215F then instantly jumps down to 200F then back up.
Old May 4, 2011 | 05:10 PM
jvanbrecht's Avatar
No, your lifters have nothing to do with the temp sensor, that is a completely different problem.
Old May 5, 2011 | 12:45 AM
C63newdude's Avatar
C63 AMG
Mine reads 215 degrees 100% of the time. I ran the car at the dragstrips a few times and it went to 242 degrees but quickly cooled down. You might have a faulty sensor because everyone seems to get about the same temps.
Old May 5, 2011 | 01:26 AM
bobbymatthews's Avatar
ML63
Oil change ASAP! ya never know.
GO for an oil change, make sure they use the recommended viscosity...nothing to thick.
Then see if its still an issue.
Similar situation on my ML63 AMG
It has cleared up since!
Ill do the oil change every 5k now!
NJOY NJOY
