C63 AMG (W204) 2008 - 2015
Old Jun 10, 2015, 03:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Engine Cover Clips
Old Nov 30, 2011 | 10:48 PM
JonMBZ's Avatar
06 C55, 09 E350
Looks fairly similar to a wood grain door molding clip on a W220 S-class. Might want to give it a try.
008-988-51-78 or 011-988-44-78
Old Aug 8, 2013 | 09:05 PM
7UP2U's Avatar
08 ML350 / 08 ML63
Hey guys just wanted to add that you can find these clips at the autobody repair shop supply store.I wish all I needed was a clip but as my luck would have it my cover is cracked front and center
Old Feb 11, 2020 | 11:46 AM
Austinking9's Avatar
2011 C63 AMG
Originally Posted by SonnyakaPig
I think it's really flimsy. Cracks easy. That's just my experience though.
Do you know where to find a replacement or is the dealership the only way? cannot find anything other than CF.
Old Feb 11, 2020 | 11:50 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
As a last resort, you can purchase the engine cover from the dealership. But I would first look on eBay. https://www.ebay.com/sch/i.html?_fro...cover&_sacat=0
Old Jun 8, 2020 | 09:25 PM
Xguy's Avatar
2011 S63 , 1997 SL500 La costa edition (sold) 1987 560SEC (sold)
https://www.amazon.com/Garnish-Interior-Bezel-Scuff-Plate/dp/B0040D0NNW/ref=pd_sbs_263_4/138-7970063-5196361?_encoding=UTF8&pd_rd_i=B0040D0NNW&pd_rd_r=3921689e-a06a-41c7-b931-bf7ceaa6cea7&pd_rd_w=zm7TR&pd_rd_wg=OmoSb&pf_rd_p=665be1f4-8d3b-46dd-91b4-582d3cec8dd6&pf_rd_r=NY4VTBWRDQRPG6DR9B00&psc=1&refRID=NY4VTBWRDQRPG6DR9B00 https://www.amazon.com/Garnish-Interior-Bezel-Scuff-Plate/dp/B0040D0NNW/ref=pd_sbs_263_4/138-7970063-5196361?_encoding=UTF8&pd_rd_i=B0040D0NNW&pd_rd_r=3921689e-a06a-41c7-b931-bf7ceaa6cea7&pd_rd_w=zm7TR&pd_rd_wg=OmoSb&pf_rd_p=665be1f4-8d3b-46dd-91b4-582d3cec8dd6&pf_rd_r=NY4VTBWRDQRPG6DR9B00&psc=1&refRID=NY4VTBWRDQRPG6DR9B00
Old Jun 8, 2020 | 09:29 PM
Xguy's Avatar
Are these the same ?
Old Jun 8, 2020 | 09:49 PM
  #32
p31c63amg's Avatar
12-P31 C63 Coupe- 19-GLC 63 S COUPE -18-911 TURBO S 19 AMG GTR COUPE
It would be nice to be able to take it off without fear of cracking it. Seems like a really poor design as the plastic cover can crack in an instant.
use some dielectric grease on your clips.
Old Jun 9, 2020 | 08:35 AM
  #33
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Originally Posted by Xguy
I have tried these and they don't fit the best, someone else said they found a part number from Mercedes so tried them, I have some pics side by side, they are not the same, but work better than the GM ones and are the closest I have seen. MB Part 011-988-89-78
Old Jun 9, 2020 | 09:54 AM
  #34
Yuille36's Avatar
All you have to do is use either needle nose pliers or regular pliers to give them a little squeeze to tighten them up, so they clip on better and that’s it. 😁
Old Jun 9, 2020 | 01:28 PM
  #35
Xguy's Avatar
are youn saying the amazon ones I posted will work ?
Old Jun 9, 2020 | 03:05 PM
  #36
ecohen2's Avatar
So those appear to be available on eBay: https://www.ebay.com/itm/Genuine-Mer...-/291943666570
I found the same part at: https://www.eeuroparts.com. for less...
I am going to order some and see if they fit...
Ed
Old Jun 9, 2020 | 03:38 PM
  #37
Yuille36's Avatar
Absolutely they will work, I bet my life on it. As they are the exact same ones, I purchased from Mercedes until I found them cheaper online.
Old Jun 9, 2020 | 05:37 PM
  #38
Xguy's Avatar
Good because I just got a reply from the ebay seller and he/she is charging $8 + for each clips that's ridicilous , amazon are like 65 cents a piece, I'm ordering right now , it's free return on prime anyway if they didn't fit. thanks for the info.
Old Jun 9, 2020 | 06:48 PM
  #39
DJ_Quaaludes's Avatar
W204 C63 AMG 507
https://www.fcpeuro.com/products/mer...des-0119888978
Old Jun 10, 2020 | 06:47 AM
  #40
Yuille36's Avatar
and if my memory serves me correctly the dealership charged me like $3 for just one. So I have a few extra if I every need them. $8 for just one is ridiculous, as these clips probably costs $ .02 to make. 🤔
Old Jun 15, 2021 | 10:18 PM
  #41
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
Just noticed that I am missing the front engine cover clip on my W166 ML63. Has anyone had these clips fall off themselves due to heat cycles? Reason I ask is because I am the only one that services my car at the moment and the last time I took my cover off I had all the clips in tact. The front clip was loose though, but I used pliers to secure it a bit more to the peg. My thought is that it must have fell through the fastening point while I put load on the engine or something of that sort.
I did look around in the engine for signs of it but don't seem to see anything. I found the part on FCP euro and ordered it along with some other items that I needed. I am a bit annoyed, however, because I can't help to think its laying somewhere on my engine or on the underside shielding. I guess I'll find out in 4,800 miles when I change my oil again.
