Eyelid Staying lit..
Please let us know what the problem ends up being. I am experiencing something very similar.. Plenty of CEL's from purge valve- Entire purge valve system gets replaced, then leads to "system too lean bank" error code just like the one you listed above (P0171)....My guess is that its from the removal of the charcoal filters so i will likely just buy another set if it keeps coming on.
Sorry about the OT post.
i asked because i know at least two other cars not including mine that had P0171 with purge valve replaced. Had the intake manifold gasket replaced along new bolts and it seems to have solved the problem.
back to topic, did you try reseating the leds?
08 C63, 07 ML63, 92 500E, 70 300SEL 6.3, 63 220 SEB Conv. Sold 02 G500, 97 E50,92 C280,71 280SE 4.5
My problem is a little different, Lights are all stock bi-Xenon. When parked, Sometimes the right parking light (front and rear) flickers on and off. This goes on for a few to several minutes then goes away. Im sure lights are not in <P> mode but not sure if it happens in both off and A mode. My car is an US model
Sorry to bring this thread back.... Where are you guys ordering your LEDs for the eyelids from? Are the eyelids the only place you are running LEDs?
