C63 AMG (W204) 2008 - 2015
Some questions on the Evosport Pulley
Old Jun 4, 2011 | 03:14 PM
aznkuja328's Avatar
12 M156 C204
I have some questions about the Evosport pulley system for those who have their pulleys installed.
1) Do you find it problem free so far?
2) Does it affect the a/c system?
3) Does it require you the change the v-belt after some time?
4) What's the difference between the modified bolt and the oem bolt?
5) Do you have a spare copy of the installation/instruction manual to share with me (pdf would be perfect)?
Your help is much appreciated! Thanks a lot!
Old Jun 4, 2011 | 06:59 PM
brad @ evosport's Avatar
PREMIER SPONSOR
None fast enough!
I will address some as appropriate. I would recommend you find Superlubricity's post on the pulley install and dyno as well (search for it).
1. I will let independent replies answer this
2. No
3. No more than stock
4. The head is shaved off of a stock bolt to fit the pulley correctly
5. Give me your email and I can send them.
brad
Old Jun 4, 2011 | 09:42 PM
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Zero problems.
My install, dyno and write-up here -> https://mbworld.org/forums/c63-amg-w...-2010-c63.html
Old Jun 5, 2011 | 05:49 AM
aznkuja328's Avatar
12 M156 C204
Thanks guys!
