Ticking sound
Mercedes C63
Ticking sound
Hi I got my ECU for 3 days ago I installed it whitout a problem.
Yesterday I got my car from the shop they installed Cargraphic headers to the stock midpipes.
The car runs so strong and the sound is sick.
But I started to get a ticking sound yesterday.
It dosent matter if the enginge is cold or warm.
It doesnt incrase when I press the gas pedal so the frequency is the same all the time.
The strange thing is that I can hear it best from the cabin if I open the hood I cant hear anything only from the cabin and If I stand next to the car. Sometimes the sound dissapears.
I think its from the headers. It is not loud at all it must be really quiet so you can hear the sound. Also if I press the gas pedal a litle bit and let go when the RPM goes down the sound dissapears and after a few seconds it comes back. Will se if I can record it tomrow.
What do you guys think?
The car is from july 2009 and only has 15 000km.
2010 C63, 2003 C230 coupe
Mercedes C63
I checked the oil level it shows OK. I did a B-service for 1 month ago they filled up 8,5 liter mobil 1. But maybe I have to refil litle? Strange thing is I cant hear the sound if I open the hood.
2011 P31 C63 2015 CLA45
Engine takes about 9l, oil cooler about 1l. My car was serviced with 10l, and oil is at top red notch. No frothing, runs fine. I've heard it tick for very short periods of time, in the 5seconds range. Everyone says it's normal. I was also wondering, would the dash light up anything if you have too little or too much oil?
Also my sound was hard to hear, it was noticible in the cabin under light acceleration and only when applying throttle.
Mercedes C63
Did you check via the dash or the dipstick under the hood? I used the dipstick, and it was close to the bottom of acceptable. Topped it off and sound was gone.
hi via the dipstick. Mine is under idle and when I drive very slow.
Do you guys think I should fill up whit 0,5 liter?
I saw when the tech changed my oil he drained the oil and the oil from the oil cooler.
C63, C300, 911TT x 3, 911 C2 x 2, 911SC, SL65, SL500, 280SL Plus some trucks
You would have to have low oil pressure to get ticking from a sticky hydraulic lifter and the frequency would vary with RPM.
Jim
Jim
Mercedes C63
08 C63 AMG, 09 Range Rover Sport Supercharged, 09 Audi A8L, 09 Ferrari California, 08 S Class
Im really glad somebody has mentioned this. My car has been making a ticking sound as well and I had no idea why it was/what it could be. Should I take her into the dealership, is it something serious? Im just worried and care about my car....
The aluminum parts tick as they expand and contract from heat. Probably nothing. If you can't hear well enough to isolate it, you can get a mechanics stethoscope at Pep boys to help narrow it down.
Jim
Jim
