alignment specs
2009 C63 with Eurocharged tune and charcoal delete
alignment specs
Does anyone have the complete factory front and rear alignment specs (including the acceptable plus/minus ranges) for the 2008-2011 C63? Not looking for guesses or estimates, just the real factory specs. Thanks.
Not with stock wheels or suspension but Here is a link with 19" wheels + H&R springs before and after alignment.
https://mbworld.org/forums/4721002-post9.html
Thanks for the response. Couple questions: What is the source of your info, and are you sure that those toe numbers are per side and not total toe. That's a huge amount of toe-in at the rear, is it not?
Even the lower C class and CLK's models call for a bunch of rear toe. We are now having
our alignment shop set the rear toe to the minimum spec. or a tad less.
