C63 AMG (W204) 2008 - 2015
Dealer visit, brake flush necessary?
Old Aug 30, 2011 | 11:39 AM
DutchC63's Avatar
C63 AMG 2009
My 09 C63 titled on 12/2009 went in for oil service today at 16.5Kmls.
Will do the MIP upgrade as well and the service adviser told me that a brake flush is recommended every 2 years with the heat and humidity in Houston, price around $ 200.00
Is this necessary? I dont do track and brakes feel very good actually.
He also suggested to change the airco filter priced at $ 225.00
I thought that this was rather pricey.
Any commends on this would really appreciated.
BTW the car definitely has an old car smell inside , in fact it stinks like hell so told them to go ahead and do it.
E
Old Aug 30, 2011 | 11:51 AM
Mr.Benzo's Avatar
02 C32 AMG, 06 C230 Sport (Gone)
It is a REQUIRED maintenence item by Mercedes Benz every 2 years or 20 k miles, but that price is very high. I work in an expensive area and we charge $155 for that flush.
Old Aug 30, 2011 | 11:53 AM
Even Money's Avatar
'15 VW GTI
It is every two years, in fact, I think it's two years from when it was built, not when you bought it.
Old Aug 30, 2011 | 11:57 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Not sure about the Aircon, but you can do the brakes easily yourself, search amazon for a pressure bleeder (mine cost around $50). It is actually one of the easier (although if you don't have a lift, labour intensive) jobs you can do yourself.
Old Aug 30, 2011 | 12:08 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
An indy shop will perform the brake flush for a lot cheaper than what the dealership is charging you. Your cabin stinks because you need a new cabin filter. Those can be purchased online and you can do it yourself. They are relatively inexpensive and they are definitely not $225.
Old Aug 30, 2011 | 12:10 PM
JeffDL's Avatar
C63
I just had brake fluid done $129.99 at the dealer. Too bad you can't price match with other dealers.
Old Aug 30, 2011 | 12:27 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I have you all beat, brake flush at Benz Elite Automotive in Alexandria VA for $83.00 including tax. And everyone is right about the brake flush, brake fluid is hydroscopic meaning it absorbs moisture, just like oil and water don't mix, neither does brake fluid, so water will travel to the lowest point meaning the pistons on the calipers, and will start to rust the piston. Thereby causing braking problems. And be careful with brake fluid, as it will instantly take off the finish of your paint, it only takes one drop, and your paint is ruined. But as far the cabin filter goes, there cheap and you can do it yourself. Paying the dealer $200 for a $22 filter is crazy, pay me $200 and I will do it for you It's a pain, because it's in a difficult position, trust me I know first hand. I even created a thread about it.
